Special Relativity and spacecraft
The discussion revolves around a problem in special relativity involving a spacecraft traveling at relativistic speeds relative to Earth. The original poster presents a scenario where the spacecraft measures a time interval of 32 hours between two events on Earth and seeks to determine the time interval at a different speed of 2.82x10^8 m/s.
  • Participants explore how to apply the time dilation formula and question the interpretation of the time interval and the spacecraft's motion relative to Earth. There are inquiries about the meaning of "32H" and whether the events occur at the same location on Earth.
The discussion includes attempts to clarify the problem's wording and the assumptions about the spacecraft's trajectory. Some participants have provided guidance on how to approach the transformation of time between different inertial frames, while others have expressed confusion regarding the initial setup.
Participants note that the spacecraft's speed suggests it cannot be orbiting Earth, and there is a focus on understanding the implications of the given speeds and time intervals in the context of special relativity.
sean-820
A spacecraft is traveling around Earth at 1.8x10^8m/s relative to the earth. If the spacecraft determines two events on Earth to be 32H, what time interval would they find if the spacecraft is traveling at 2.82x10^8m/s?
delta Tm=delta Ts/[1-(v^2)/(c^2)]
Where Tm= time viewed by a moving object
Ts= time viewed y a stationary object
v= velocity
c= speed of light=3x10^8m/s
This is the equation i know, but i don't know how to incorporate the 32h from just the spacecraft s frame of reference
v= velocity
The spacecraft can't be traveling "around" the Earth at this speed if you mean that it is circling the earth. Does 32H mean 32 hours? Are the events at the same location on the earth? Can you give us the exact wording of the question?
AM
The spacecraft can't be traveling "around" the Earth at this speed if you mean that it is circling the earth.Yes its path is around Earth at that speed. Does 32H mean 32 hours? yesAre the events at the same location on the earth?yes Can you give us the exact wording of the question?
A spacecraft has a speed of 1.8x10^8m/s with respect to earth. The spacecraft determines two events on Earth to be 32 hours apart. What time interval would they find if the spacecraft is traveling at 2.82x10^8m/s (instead of 1.8x10^8)?
Ok. The question simply states that it is moving at a constant speed relative to the Earth ie. in a straight line. It has more than enough escape velocity so it cannot be going around the earth.
How do you transform time from one inertial frame to another?
AM
I solved it. The answer is 75 hours. I think it was more the wording of the question that messed me up. Escape velocity wouldn't matter as it isn't necessarily orbiting earth.To solve, i just used the formula given twice. First time to sub in the initial velocity and time to get the stationary observers time, then did the equation again using this stationary time to find time observed by the spacecraft at its new speed.
Thanks for trying to help
  • · Replies 26 ·
