Special Relativity - clocks on two trains
  • Level: Undergrad
  • Thread starter Mike_bb
98 replies · 8K views · last reply
Mike_bb
Hello, PF!
Example: Two trains are moving in opposite directions with constant velocity ##V##. Clocks in the trains are synchronized at start point. Clocks on the platform are synchronized too. Left clock and right clock on the platform read 4sec. Due to time dilation clocks in the trains read 2sec.
Diagram of two trains moving apart in opposite directions, each marked with an arrow labelled V, with a platform clock reading 0 at the centre and 4 at each end and train clocks reading 2, with curved arcs labelled delta x between them.
Observer in the left train see the clock (1) in the left train and read the clock (2) in the right train and conclude that clock (2) is slowed.
Observer in the right train see the clock (2) in the right train and read the clock (1) in the left train and conclud that clock (1) is slowed.
My question: Is it possible that differences in time are the same (due to given conditions and relativity of simultaneity)?
For example, for observer in the left train: clock (1) = 2sec; clock(2)=1.5sec and for observer in the right train: clock (2) = 2sec; clock(1) = 1.5sec.
The difference in time for observer in the left train = 2sec-1.5sec=0.5sec.
The difference in time for observer in the right train = 2sec-1.5sec=0.5sec.
Thanks!
I'm not completely clear on the scenario (probably my fault), but you are correct that the time dilation is the same regardless of the direction of the relative velocity.
If I correctly understood your setup then, yes. Not only is it possible, it is required. Otherwise one inertial frame would be distinguished from the other. That would violate the principle of relativity.
I meant following: for the left train: clock(1)=2sec; clock(2)=1.5sec and for the right train: clock(2)=2sec; clock(1)=1.5sec. The difference in time is 0.5sec (relativity of simulteneity).
Right?
You refer to this, but I'm not sure you realize how it works in this scenario. It refers to the synchronization of the clocks within the two trains' Inertial Reference Frames (IRFs) being different. Each train thinks that the clocks along the path of other train's IRF are synchronized incorrectly.
This isn't relativity of simultaneity, just basic symmetry.
Relativity of simultaneity here would be for example how the clocks on the platform are desynchronized in each train frame. But you don't use the clocks on the platform at all as far I can see, so what did draw them for?
Yes, symmetry for ##\Delta t## and ##\Delta t'## . But time difference exists (not always, only when clocks are synchronized in one system) due to relativity of simultaneity. I wrote that time difference is 0.5sec. I think, in my example ##\Delta T = vx/c^2 = 0.5sec##
Edit: arithmetic was wrong, as noted by PeterDonis below.
It really helps if you actually give all the details of your experiment, instead of us having to back them out of your description.
You seem to be considering two trains moving at ##\pm c/\sqrt{2}## relative to the platform, so with ##\gamma=2## for both of them in the platform frame. The event where they pass each other is the origin of coordinates. Each train has a clock, and there are also two clocks at rest on the platform ##\pm 2\sqrt{2}\mathrm{ls}## from the origin as measured in the platform frame. All clocks are synchronised to their rest frame time - in particular this means that in the platform frame all read zero at the instant the trains pass one another.
Now we can write down a list of interesting events. Using T+ and T- to refer to the clocks on the trains moving in the positive and negative x directions respectively, and P+ and P- to refer to the platform clocks with positive and negative x coordinates respectively the events and their coordinates ##x_p, t_p## in the platform's rest frame are:
##x_p/\mathrm{ls}####t_p/\mathrm{s}##
P+ zeroed##2\sqrt{2}####0##
P- zeroed##-2\sqrt{2}####0##
T+ zeroed##0####0##
T- zeroed##0####0##
T+ and P+ meet##2\sqrt{2}####4##
T- and P- meet##-2\sqrt{2}####4##
Now you have coordinates for each event you can apply the Lorentz transforms:$$
\begin{eqnarray*}
x'&=&\gamma(x-vt)\\
t'&=&\gamma\left(t-\frac{v}{c^2}x\right)
\end{eqnarray*}
$$where ##\gamma=(1-v^2/c^2)^{-1/2}##, to get the coordinates used by other frames (##x_\pm,t_\pm## for the rest frames of the trains travellibg in the ##\pm x## direction):
##x_p/\mathrm{ls}####t_p/\mathrm{s}####x_+/\mathrm{ls}####t_+/\mathrm{s}####x_-/\mathrm{ls}####t_-/\mathrm{s}##
P+ zeroed##2\sqrt{2}####0####4####-2\sqrt{2}####4####2\sqrt{2}##
P- zeroed##-2\sqrt{2}####0####-4####2\sqrt{2}####-4####2\sqrt{2}##
T+ zeroed##0####0####0####0####0####0##
T- zeroed##0####0####0####0####0####0##
T+ and P+ meet##2\sqrt{2}####4####0####2\sqrt{2}####8####6\sqrt{2}##
T- and P- meet##-2\sqrt{2}####4####-8####6\sqrt{2}####0####2\sqrt{2}##
Now, you asked about the time difference at the meetings as determined in the rest frame of one of the trains. You can simply consult the table - the ##t_+## coordinate is the time measured using the rest frame of the train moving in the +x direction, and in this frame the T+ and P+ clocks meet at ##t_+=2\sqrt{2}\mathrm{s}## and the T- and P- clocks pass at ##t+=6\sqrt{2}\mathrm{s}##. So the difference in this frame is ##4\sqrt{2}\mathrm{s}##.
This is not the 0.5s you are citing, but you have not shown your work, so we have no idea if you are wrong or just doing something different.
Not quite; for ##\gamma = 2## you need ##v / c = \pm \sqrt{3} / 2##. For ##v / c = \pm \sqrt{2}## you get ##\gamma = \sqrt{2}##. Remember the square root in the formula for ##\gamma##.
Actually just a complete brainfart, I think. I "remembered" the wrong ##v## value corresponding to ##\gamma=2## and failed to notice the resulting inconsistency in my outputs. I've struck out the text above and will post a corrected version shortly.
@Mike_bb - notice that because I stated clearly my starting points, intermediate values, final results, and my reasoning to get from one to another, Peter was able to pinpoint exactly where I made a mistake. I still don't know what exactly you think the half second you've calculated actually is.
Corrected (I hope!) version of my struck-out post above. At least the ##t_+## coordinates of the plus clocks meeting and ##t_-## coordinates of the minus clocks meeting are 2s this time.
You seem to be considering two trains moving at ##\pm c\sqrt{3}/2## relative to the platform, so with ##\gamma=2## for both of them in the platform frame. The event where they pass each other is the origin of coordinates. Each train has a clock, and there are also two clocks at rest on the platform ##\pm 2\sqrt{3}\,\mathrm{ls}## (four seconds' travel at ##c\sqrt{3}/2##) from the origin as measured in the platform frame. All clocks are synchronised to their rest frame time - in particular this means that in the platform frame all read zero at the instant the trains pass one another.
P+ zeroed##2\sqrt{3}####0##
P- zeroed##-2\sqrt{3}####0##
T+ zeroed##0####0##
T- zeroed##0####0##
T+ and P+ meet##2\sqrt{3}####4##
T- and P- meet##-2\sqrt{3}####4##
\begin{eqnarray*}
x'&=&\gamma(x-vt)\\
\end{eqnarray*}
$$where ##\gamma=(1-v^2/c^2)^{-1/2}##, to get the coordinates used by other frames (##x_\pm,t_\pm## for the rest frames of the trains travelling in the ##\pm x## direction):
P+ zeroed##2\sqrt{3}####0####4\sqrt{3}####-6####4\sqrt{3}####6##
P- zeroed##-2\sqrt{3}####0####-4\sqrt{3}####6####-4\sqrt{3}####-6##
T+ and P+ meet##2\sqrt{3}####4####0####2####8\sqrt{3}####14##
T- and P- meet##-2\sqrt{3}####4####-8\sqrt{3}####14####0####2##
Now, you asked about the time difference at the meetings as determined in the rest frame of one of the trains. You can simply consult the table - the ##t_+## coordinate is the time measured using the rest frame of the train moving in the +x direction, and in this frame the T+ and P+ clocks meet at ##t_+=2\mathrm{s}## and the T- and P- clocks pass at ##t_+=14\mathrm{s}##. So the difference in this frame is ##12\mathrm{s}##.
Ibix, my question was easier and values of time are arbitrary (not exact).
" Is it possible that differences in time are the same (due to given conditions and relativity of simultaneity)? "
I asked about moving trains without reminding the platform. Platform can be removed from my example.
Clocks on the trains read the same time (4sec). Trains move with constant velocity ##V##.
Time difference are the same because of symmetry and relativity of simulteneity. Right?
So it was just there to confuse (mainly yourself)?
As already said, without the platform clocks, it's just symmetry.
Relativity of simulteneity only comes in when you have spatialy separated clocks at rest relative to eachother, like the platform clocks. If you sync those in one frame, they will have an offset in other frames.
Ok. Symmetry works with interval of time ##\Delta t## and ##\Delta t'##. For example (arbitrary values of time),##\Delta t = 10sec## ##\Delta t' = 8sec## for clock 1-2(left train) and ##\Delta t = 10sec## ##\Delta t' = 8sec## for clock 2-1 (right train).
But how to explain that clocks in the trains have the same time difference without relativity of simulteneity?
Time difference for clock1 (left train) = 10s-8s=2s; Time difference for clock2 (right train) = 10s-8s=2s; ?
Relativity of simualtanity can be shown with lightning strikes at both ends of a passing train car by a platform. In platform frame the lightning strikes are simultaneous . The observer in center of train car sees the time between strikes:
Equation on white background: Δt′ = γ v Δx / c², with γ multiplying the fraction v Δx over c squared.
The fact that clocks are synchronized differently in different Inertial Reference Frames is the basic result of the relativity of simultaneity. The fact that the time difference is equal is due to symmetry. Those are different statements due to different logic. But if you look carefully at the details of relativity of simultaneity, you will see that the symmetry is assumed. In that, there is no preferred IRF, so there is symmetry. Experimental results forced the assumption of no preferred IRF, and led to those conclusions.
Perhaps term "time difference" isn't correct exactly. What is the "time difference" ? What do you mean?
Then you should leave them as variables. But that is not the main point others are trying to get across to you.
Regardless of whether your numbers are arbitrary (leave them as variables) or concrete (numbers with units), what you need to improve is the description. Whenever you give a number or a variable, give enough of a description that it is unambiguous what that number or variable means.
A word like “time difference” is fine, but not clear. What two specific time values are being subtracted to get a difference? Something like “the time difference is the time on one clock minus the simultaneous time on the other clock with simultaneity determined by the first clock’s frame”. That description is what is missing and it is required whether you are giving numbers or variables.
I agree with you. I should have to use variables instead of arbitrary numbers!
Is there way to calculate ##\Delta t' = vx/c^2## for two clocks in the two moving trains?
Let clock 1 in the left train read T sec and clock 2 in the right train also read T sec?
As I understand ##\Delta t'## for left and right trains will be the same?
From time dilation which is symmetric.
Or from the full Lorentz Transformation, which contains all 3 aspects : length contraction, time dilation and relativity of simultaneity. Then you don't have to worry about which of them applies when.
My calculations are here. The rest frame - left train. I obtained wrong result (5.51sec instead of 4sec) .
Could anyone explain where did I go wrong? Thanks!
Handwritten physics working: a sketch of two trains moving apart with speeds v1 and v2 and gap delta x/2 each side, then time dilation equations ending in a result of about 5.51 sec compared with 4 s.
In your calculation, what are the primed and the unprimed variables?
In the first section after the picture you are calculating two spacetime intervals and setting them equal to each other. Which spacetime intervals are being calculated and why are they equal?
At the end of that first section you have ##\Delta x = L = 8c##, which ##\Delta x## should be a length but ##8c## is a speed.
In the second section the formula ##\Delta T## uses a capital ##T## instead of lower case ##t##. Is there any significance to that?
In the second section, it is unclear where the initial formula arises.
Mike_bb said:
No. There is no mistake.
What is your V supposed to represent?
##V = \frac{2v_1}{1+v_1^2/c^2}##
##8c##=8*300000. I denoted "c" as dimensionless unit in this case (for convenience).
This formula is used for calculating "effect of simultaneity". I don't know how to say this in English.
Top right corner says ##V=2|\vec{v_1}|##.
And you still didn't explain what ##V## is supposed to represent physically.
