Special relativity momentum and energy conservation
6 replies · 2K views
Taylor_1989
Two identical particles of mass m travel towards each other at speed v; they combine and form a single new particle. By employing conservation of momentum and conservation of energy, what is the mass of this new particle in
Relativistic momentum and total energy , possibly lorentz velocity transformation
I am completely lost to where to start with this, because of two reasons. I can see if I need to use a frame of reference, I not sure if the v<<c and do I take the velocity as a vector?
I know the momentum and total energy are consevered in relativity but in the question I see that if the final momentum is equal to the sum of the initial surely this 0 because they are moving at the same speed and they are the same mass, so how can they even move at a speed after the collision. My lecture has not explained this very well in his notes and I am very lost could someone please help me.
Also tell me what the latex tags are for the physics forum. Big thanks in advance.
I think it's safe to assume that "towards each other" means a head-on collision. So, momentum before the collision is 0, as you suspected.
Latex in line ##E = mc^2## or isolated: $$E = mc^2$$
Something to think about to clarify your thinking on the velocity and Lorentz transform: would the answer be any different if you were to use a reference frame in which one of the particles is at rest?
Personally, I would prefer the centre-of-momentum frame for his one!
Thank for the response guy, I just had another look and it dawned on me. I mean momentum would be 0 and then I could total energy of the system is equal to the rest energy hence [math]E=mc^2[\math]
You have to enclose the math in side two # or two $
eg:
#`# e = mc^2 #`#
or $`$ e = mc^2 $`$
just don't put ` in between.It is to stop the rendering of math.
No. If the collision is perfectly inelastic (all kinetic energy converted to mass) then the mass afterwards would NOT be ##2m## in the relativistic case. (In the classical case we would not have conservation of energy because mass end energy are not equivalent in that regime.)
