Specific Heat and Maybe Latent Heat also
The problem involves the transfer of heat between aluminum and water, specifically examining the effects of temperature change and potential phase change of water into ice. The context includes specific heat capacities and latent heat values relevant to the materials involved.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss whether to include latent heat in their calculations and how to set up the energy conservation equation. There are questions about the correct signs and the implications of temperature changes on the calculations.
Some participants have provided guidance on checking the signs in equations and the importance of determining whether all water converts to ice. There is ongoing exploration of the relationships between heat gained and lost, with various interpretations being discussed.
Participants express uncertainty regarding the phase change of water and the associated calculations. There are mentions of potential confusion with algebraic signs and the need to clarify assumptions about the final state of the water.
twilos
Several small piece of aluminum, having total (combined) mass of 2.5 kg are placed in liquid nitrogen and, when removed, are at a temperature of -135C. The aluminum is transferred to an insulating container with 0.50 kg of water. The water is at 25.0C [ Ignore heat lost from the system]
C Al = 910 J/kg K
C water = 4190 J/kg K ; Lf = 334000 J/kg ; Freezing pt = 0C
C ice = 2100 J/ kg K
Q = mc(change)T
Lf = mLf
Conservation of Energy ( because system is isolated )
Qcold = -Qhot
Before I attempted to do this problem, I wasnt sure if there would be a latent phase change for the water to ice because if there was then I would include that eq. Lf = mLf into my solution.
Gained Energy = Aluminum from water
Lose Energy = Water from Aluminum
(2.5 kg)(910 J/kg K)(T - (-135C)) = - (0.5 kg)(4190 J/kg K)( T - 25C)
2275(T + 135C) + 2095 (T - 25C) = 0 ?
I am unsure if that's what your suppose to do and is it suppose to be +135C?
You have to include Lf. So heat lost part include, heat lost by water from 25 degree to zero degree + heat lost by ice from zero degree to T degree.
(2.5 kg)(910 J/kg K)(T - (-135C)) = - (0.5 kg)(4190 J/kg K)( 0 - 25C) +(x)(334000 J/kg) + (2100 J/ kg K)( T - 0C)
Is this what your talking about? Because then there's 2 variables X because you don't know the amount of water that changes into ice...?
To check whether the water completely convert in ice or not, calculate amount of heat absorbed by aluminum to reach 0 degree, and amount of heat lost by the water to convert water from 25 degree C to 0 degree C ice. If first one is greater than the second,water is completely converted into ice. Other wise a part of water is converted into ice.
that is necessary to find the temperature final? And if its partially converted doing what you said will give a ratio of how much ice is in the water?
Yes.
okay so the following i did:
Qal = (2.5kg)(910 J/kg K) (135C) = 307125 J
Qw = (0.5kg)(4190 J/kg K) (25C) = 52375 J
Therefore the amount of heat for water is less than Aluminum so all of the water turns into ice?
then i can just do :
(2.5 kg)(910 J/kg K)(T - (-135C)) = - (0.5 kg)(4190 J/kg K)( 0 - 25C) +(0.5 kg)(334000 J/kg) + (2100 J/ kg K)( T - 0C)
and solve for T?
Before that check the signs and parenthesis.
damn i can't get it to work out like i am really bad with the algebra lol anyone help me simplify this please?
(2.5 kg)(910 J/kg K)(T - (-135C)) = - (0.5 kg)(4190 J/kg K)( T - 25C) +(0.5 kg)(334000 J/kg) + (2100 J/ kg K)( T - 0C)
i believe all the numbers are correct however I am always confused because of the positives and negatives... and the left side is gaining heat and the right side is losing heat. So the left side has a Negative to begin with. Also the Aluminum is at -135 does that cancel out the - from Tf-Ti?
To avoid confusion in signs, if heat is gained use Tf - Ti. If heat is lost, use Ti - Tf.
Then use heat gained = heat lost.
