Specific heat capacity (Calorimetry)
The discussion focuses on calculating the temperature rise in steel brake disks due to kinetic energy conversion during braking. A 1500 kg car traveling at 32 m/s comes to a stop, and the kinetic energy is converted to heat in the brake disks. The relevant equation involves specific heat capacity, mass, and temperature change, specifically c = Q/(m*dT). Participants clarify that the kinetic energy of the car can be calculated using the formula 1/2*mv^2, and this energy is distributed equally among the four brake disks. The final temperature rise calculated is 120 degrees Celsius.
Lunar Guy
[SOLVED] Specific heat capacity (Calorimetry)
When a driver brakes an automobile, friction between the brake disks and the brake pads converts part of the car's translational kinetic energy to internal energy. If a 1500 kg automobile traveling at 32 m/s comes to a halt after its brakes are applied, how much can the temperature rise in each of the four 3.5 kg steel brake disks? Assume the disks are made of iron (c_{p} = 448 J/kg•°C) and that all of the kinetic energy is distributed in equal parts to the internal energy of the brakes.
c_{p,x}m_{x}T_{x} = c_{p,y} m_{y} T_{y}
I really don't know where to start with this problem... A little push and I can do the rest, but...
Bump. Can anyone help me out?
Well that's not really the right equation involving specific heat you're looking at
You want the one that involves energy. You know the kinetic energy of the car from 1/2*mv^2, and it's given that all that energy becomes heat
A 4th of that goes into each 3.5kg brake, so do you have a formula that links specific heat, mass, temperature, and heat? (yes you do)
\DeltaPE + \DeltaKE + \DeltaU = 0?
Well you could infer the equation from the units if you didn't know off hand(energy/mass*temp
c=Q/(m*dT) where dT is the change in temperature and Q is the amount of heat gained(which you find from assuming all the kinetic energy becomes heat)
Thanks. I got it. It's 120 degrees Celsius, right?
