Specific Heat Capacity Question - Unknown Mass
The problem involves calculating the mass of a solid that changes to liquid when thermal energy is supplied at a constant rate. The context is specific heat capacity and latent heat, with a focus on the energy required for phase change.
  • Participants discuss the total heat energy supplied over a time interval and the need for unit conversion from minutes to seconds. There is also exploration of the concept of specific latent heat of fusion and its application to find mass.
The discussion has progressed with participants clarifying the calculations and concepts involved. Some guidance has been provided regarding the interpretation of specific latent heat and how to apply it to find the mass of the solid melted.
Participants express varying levels of confidence in their understanding of the physics involved, with one participant indicating a lack of familiarity with the topic. The problem is framed within the constraints of a homework assignment.
me240
Q. Thermal energy is supplied to a melting solid at a constant rate of 2000 W. Calculate the mass of the solid changed to liquid in 2.0 minutes. Assume that the specific latent heat of fusion of the solid is 95 000 J kg-1 and that heat exchange with the surroundings may be neglected.
I was doing my physics homework just fine until I came to this question. I have NO idea how to do this :s Please help!
Note: I'm really bad physics. Like REALLY bad and I've just started to get the hang of it a little.
What is the total heat energy supplied to the melting solid over the time interval?
I believe it'll be 2000 W x 2.0 minutes = 4000 J
Do I need to convert it into seconds first?
Yes, you do need to convert it into seconds because one watt of power is equivalent to one joule of energy input/output per second. W = J/s
Right.
So 2 minutes = 120 s
2000 x 120 = 240000 J
How do I find the mass now?
Good, so we've established that 240 kJ of thermal energy was supplied to melt the solid. From your inability to carry on, I gather that you have no idea what the "specific latent heat of fusion" means? The specific latent heat of fusion of a substance is defined as the energy per unit mass required to change the substance from the solid to liquid phase (ie melt it) without any change in temperature. In this case, this implies that 95 kJ of energy is required to just melt 1 kg of the solid. So, if we had to use 240 kJ of energy to melt the amount of solid that we have, how many kilograms would that be?
That makes a lot more sense now :)
240 ÷ 95 = 2.526315789
Not quite sure how to round this...
The convention is to round it so that it has the same number of significant digits as the least accurate input number. Here, you can just round to 2.5, because 95 has two significant digits.
Thank you so much both of you. This was really helpful for such a non-physics person like me.
God bless you two!
