High School Speed of light -- Why is it constant?
The speed of light, denoted as 'C', remains constant in a vacuum regardless of the observer's inertial reference frame, as established by Einstein's two postulates of Special Relativity. While light can travel at different speeds through mediums like glass or water, its invariant speed in free space is a fundamental aspect of modern physics. This constancy allows for the consistent application of physical laws across various frames of reference, resolving historical confusions in physics. The discussion emphasizes that the speed of light's constancy is not merely a coincidence but a crucial element of the geometric framework underlying relativity.
  • Understanding of Special Relativity principles
  • Familiarity with electromagnetic wave properties
  • Basic knowledge of inertial reference frames
  • Awareness of the distinction between light speed in vacuum and in mediums
  • Study Einstein's two postulates of Special Relativity in detail
  • Explore the geometric foundations of modern physics
  • Research the behavior of light in various mediums
  • Examine the implications of invariant speed in theoretical physics
Students of physics, educators explaining relativity, and anyone interested in the fundamental principles governing light and its behavior in different environments.
Docscientist
In an electromagnetic wave like light,both wavelength and frequency changes but it's speed always remains constant.Why?
russ_watters said:
Are you familiar at all with Special Relativity?
I'm sorry.I'm not.I just need a short and subtle answer for my question.The Wikipedia page confuses me with a lot of new terms I haven't yet learned.
Unlike, say, sound, light was discovered to behave as if it is independent of any medium (when in a vacuum). It is measured to travel at C by observers, regardless of inertial reference frame.
That said, it can be forced to travel through a medium like glass or water at a different speed.
And that should mean that speed of light is not constant,right?
Einstein formulated special relativity from two postulates, or two assumptions. One, that the laws of physics are the same in all inertial frames of reference. Two, that the speed of light is constant in all inertial frames of reference. In other words, Einstein offered no explanation for the constancy of light speed. He just showed that if it is constant he could explain the preceding fifty years of confusion in ten pages.
The modern approach is to start from a set of rules of geometry that are slightly different from Euclid's rules, then show that the constant speed of light falls out of them. That approach works well for going onto general relativity, but is a bit abstract. However, it brings out an important point. There is a speed which is invariant - it is the same in all frames. Light happens to travel at this speed (not a coincidence) but nothing changes about relativity if it turns out not to.
Don't worry about the speed of light in a medium. Light and matter interacting is complicated, and light only travels at the invariant speed in free space. In free space, a light pulse will always pass you at c, whatever you are doing. In a medium you aren't talking about just light anymore, so what happens depends on what the medium is doing.
Likes m4r35n357
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 25 ·
  • · Replies 93 ·
  • · Replies 18 ·
  • · Replies 51 ·
  • · Replies 74 ·
  • · Replies 72 ·
