How to Calculate the Resultant of Two Vectors in a River Crossing Situation
  • Thread starter Thread starter akxt
The problem involves calculating the resultant of two vectors in a river crossing scenario, specifically focusing on a boat's speed and velocity in relation to the river's current. The subject area pertains to vector addition and motion in physics.
  • The original poster expresses uncertainty about how to begin the problem and whether to use specific formulas for time and acceleration. Some participants suggest using vector addition to find the final velocity of the boat, while others recommend drawing a diagram to visualize the vectors involved.
The discussion is ongoing, with participants offering guidance on how to approach the problem. There is an emphasis on understanding vector relationships, but no consensus has been reached on the specific steps to take.
The original poster is seeking clarification on the use of known values in the calculations, and there is a mention of the need for visual aids to assist in understanding the problem setup.
akxt
Could someone help me with this, thanks in advance:
A man can row a boat at the rate of 5.0km/hr in still water. He points the boat directly across a river which flows at the rate of 5km/hr.
a) Find the boat's final speed
b) Find the boat's final velocity
I don't know where to start. Do I use a formula to figure out t then another formula to figure out a and then so on?
If you can do this, i would appreciate it if you can explain your reasonings, thanks.
Regarding b) : the final boat velocity vector equals: \vec{v}_{B} = \vec{v}_{R} + \vec{v}_{B,R}. In words, the total velocity of the boat equals the velocity of the river plus the velocity of the boat relative to the river. So, just add the two known vectors to get the final velocity of the boat. Finding the speed from a) should be simple.
Do I have to use 5 for b and r ?
Yes, of course. You know the magnitudes and the directions of the vectors, so you can solve your problem easily.
draw a picture of what you are given, then calculate the resultant of the two vectors. This should help you start out
  • · Replies 16 ·
10K
  • · Replies 30 ·
