Spherical symmetri of eigenfunctions?
3 replies · 2K views
Azael
I have been given these 4 eigenfunctions of the hydrogen atoms first 2 n-shells.
[tex]\psi_{100}(r, \theta, \phi )=\frac{1}{\sqrt{\pi a^3_0}}e^{-r/a_0}[/tex]
[tex]\psi_{200}(r, \theta, \phi )=\frac{1}{\sqrt{8\pi a^3_0}}(1-\frac{r}{2a_0})e^{-r/2a_0}[/tex]
[tex]\psi_{210}(r, \theta, \phi )=\frac{1}{4\sqrt{2\pi a^3_0}}(\frac{r}{a_0})e^{-r/2a_0} cos\theta[/tex]
[tex]\psi_{21\pm 1}(r, \theta, \phi )=\pm\frac{1}{8\sqrt{\pi a^3_0}}(\frac{r}{a_0})e^{-\frac{r}{2a_0}} sin\theta e^{\pm i\phi}[/tex]
Where [tex]a_0[/tex] is the Bohr radius.
I am suposed to show that the superposition
[tex]|\psi_{nlm}(r, \theta, \phi )|^2[/tex] is sphericaly symmetric within each shell.
Now what I don't know is how do I show spherical symmetri(not even generaly and not just in this particular case). Any hints?:confused:
do I basically just show that the superposition has the same value in a arbitrary r and -r? and the same for [tex]\phi[/tex] and [tex]\theta[/tex]
I guess I should rephrase.
How do I show that any function is sphericaly symetric? Right now my brain has frozen even though I know it must be ridicilously simple.
Ignore the -r brainfart in the previous post btw.
What I mean is that should I show the function is the same if I hold r, theta constant and replace phi with -phi and then if I hold r and phi constant and replace theta with -theta?
the first one
[tex]|\psi_{100}|^2 = \frac{1}{\pi a_0^3}e^{-\frac{2r}{a_0}}[/tex]
this is obviously sphericaly symmetric since it only depend on the radius. Its a sphere pure and simple. But is that proof enough?
The second one
[tex]|\psi_{200}|^2 = \frac{1}{8\pi a_0^3}[1-\frac{r}{2a_0}]^2 e^{-\frac{r}{a_0}}[/tex]
same as above? only radialy dependent=the function gest weaker in the radial direction, obviously spericaly symetric.
third one
[tex]|\psi_{210}|^2=\frac{r}{32\pi a^3_0}e^{-\frac{r}{a_0}} (cos\theta)^2[/tex]
Now this one. If I hold r constant and replace theta with -theta I get the same answere. So does that mean sphericaly symetric? Do I just have to say that to prove it?
In the fourth one at the end
The [tex]sin\theta e^{\pm i\phi}[/tex] should I read that as [tex]sin(\theta e^{\pm i\phi})[/tex] or [tex]sin(\theta) e^{\pm i\phi}[/tex] ??
