Spin matrix representation in any arbitrary direction
The discussion revolves around the representation of spin matrices in quantum mechanics, specifically how to express a spin matrix along an arbitrary direction defined by a unit vector ##\hat{n}##. Participants are exploring the relationship between the spin matrix and its eigenstates, particularly in the context of the Pauli spin matrices.
  • Participants discuss the need to find eigenstates of the spin matrix and whether it can be diagonalized in that basis. There are questions about the implications of specific angles ##\theta## and ##\phi## on the matrix representation. Some suggest using rotation operators to derive the spin matrix along the desired direction.
The conversation is active with various approaches being considered, including the use of eigenvectors and unitary transformations. Some participants express uncertainty about the implications of certain parameters and the conditions under which the matrix can be diagonalized. There is no explicit consensus, but several productive lines of reasoning are being explored.
Participants note that certain parameters, such as ##\phi##, have not been explicitly defined, which may hinder progress. The discussion also touches on the physical equivalence of different axes in quantum mechanics and the implications for the representation of spin states.
PhysicsTruth
Find the representation in which the component of spin along a direction ##\hat{n}## is diagonal, where ##\hat{n}## is a vector in the ##x-z## plane, making an angle ##\theta## with the ##z## axis.
##\sigma \cdot \hat{n} = \begin{pmatrix} cos(\theta) & sin(\theta)e^{-i\phi} \\ sin(\theta)e^{i\phi} & -cos(\theta) \end{pmatrix}##
##\sigma _z = \begin{pmatrix} 1 & 0\\ 0 & -1 \end{pmatrix}##
I've tried to use the 1st equation as a matrix to determine, but it clearly isn't a diagonal matrix. My guess is that I need to find the spin matrix along the direction ##\hat{n}##, but do I need to find the eigenstates of ##\sigma \cdot \hat{n}## first and check if they form a diagonal matrix or not? Can someone help me in figuring out how to proceed?
You could find the eigenvectors of that matrix, but other than that I'm not sure what the question is asking.
The matrix you've found would then be diagonal in the basis of its eigenvectors. That might be what is intended.
To be honest, the matrix doesn't have non-trivial solutions explicitly. It's only when one of the values is decided can the other value be determined. So, it might be diagonal only for a particular value of ##\theta## or ##\phi##. Also, ##\phi## hasn't been mentioned explicitly, so can't really proceed with that even.
It's manifestly Hermitian so must have an orthonormal eigenbasis. Moreover, it's physically identical to ##S_z## etc. So must have an eigenbasis.
Another way is to think about how rotations act on spinors an tgen use the rotation which maps ##\vec{e}_z## to ##\vec{n}##.
Okay, so the rotation around any unit axis ##\hat{n}## of a spinor is given by-
##Icos(\theta /2) + i(\hat{n} \cdot \sigma)sin(\theta /2)##
So here, it's getting rotated about the ##y## axis, so should I get the representation as required if I use this rotation form?
Can someone just tell me how to write a Spin Matrix along any vector rotated by an angle ##\theta## from ##z## axis in terms of the eigenbasis of ##\sigma _z## Pauli spin matrix? Is it ##cos(\theta /2) |+> + sin(\theta /2) |->##, where ##|+>, |->## are eigen vectors of ##\sigma _z## ?
In that case, I can just perform an Unitary transformation to make it diagonal. So I need to know this.
You already have the matrix in your original post. For the specific case of a direction in the x-z plane you have ##\phi =0##.
Yes, that's the eigenvector corresponding to eigenvalue ##1##. You need the second eigenvector corresponding to eigenvalue ##-1##.
You don't need to calculate the transformation to the eigenbasis, as you know it takes the matrix takes the same form as the Pauli matrix for ##S_z## in that basis.
So, would the representation just be ##\begin{pmatrix} 1 & 0\\ 0 & -1 \end{pmatrix}## in that case?
I did get this after a wholesome unitary transformation to the new eigenbasis, which is the same as the ##\sigma _z## matrix.
Yes, once you have the eigenvalues and vectors you know the matrix in that eigenbasis. Although, it can't hurt to grind out the transformation just to check!
Thanks. I have some problem to understand this intuitively. Can you just explain a bit as to why we end up getting this sole matrix when we change our basis and fix it along a direction?
The physical explanation is that the z-axis is an arbitrary choice. Any other direction is physically equivalent (and, indeed, could be chosen as the z-axis). The formalism of spin about any direction must be equivalent to the formalism about the z-axis.
Mathematically, the action of an operator is completely determined by its action on a basis. And, the action on its eigenbasis is "diagonal". You don't have to transform bases, you can study the action of the operator on that eigenbasis directly.
9K
  • · Replies 18 ·
