Undergrad Is the Spin-Rotation Constant Always Positive in Diatomic Molecules?
  • Thread starter Thread starter Malamala
    Molecule
The spin-rotation constant, denoted as ##\gamma##, can indeed take on negative values in diatomic molecules, contrary to common assumptions. Specifically, in the case of the ground state ##^2\Sigma_+##, examples such as YbF and YbOH demonstrate that ##\gamma## can be negative, influenced by second-order perturbation interactions involving spin-orbit and rotational operators. This indicates that the sign of the spin-rotation constant is dependent on the specific molecular states involved.
  • Understanding of spin-rotation coupling in molecular physics
  • Familiarity with diatomic molecular states, particularly the ##^2\Sigma_+## state
  • Knowledge of second-order perturbation theory in quantum mechanics
  • Experience with spin-orbit interactions in diatomic molecules
  • Research the role of second-order perturbation theory in molecular spectroscopy
  • Study the spin-orbit coupling effects in diatomic molecules like YbF and YbOH
  • Explore the implications of negative spin-rotation constants on molecular behavior
  • Investigate precision measurement techniques in molecular physics
Researchers in molecular physics, quantum chemists, and anyone studying the properties of diatomic molecules and their spin-rotation dynamics will benefit from this discussion.
Malamala
Hello! Can the spin-rotation constant, ##\gamma##, have a negative value in a diatomic molecule, or does it have to be positive (in my case the state is a ground state ##^2\Sigma_+##, which is about 14000 cm##^{-1}## away from the next electronic level). I don't think I have ever seen negative values for ##\gamma## in the papers I came across, but I am also not sure if there is a reason for it to be always positive. Thank you!
Hello! Sure it can, see for example the YbF and YbOH molecules that are being pursued for precision measurements. In a lot of cases, the spin-rotation constant is mostly determined by a second order perturbation interaction involving spin-orbit and rotational operators. This can be either positive or negative depending on the sorts of states involved.
Thread 'Unexpected irregular reflection signal from a high-finesse cavity'
I am observing an irregular, aperiodic noise pattern in the reflection signal of a high-finesse optical cavity (finesse ≈ 20,000). The cavity is normally operated using a standard Pound–Drever–Hall (PDH) locking configuration, where an EOM provides phase modulation. The signals shown in the attached figures were recorded with the modulation turned off. Under these conditions, when scanning the laser frequency across a cavity resonance, I expected to observe a simple reflection dip. Instead...
  • · Replies 0 ·
