Spinning friction for a small point
The discussion centers on the physics of friction experienced by a dancer spinning on her toes with a sharp-tipped metal shoe. Participants clarify that the force of friction is determined by the normal force (F = μN) and does not depend on the contact area, although the energy loss due to friction is influenced by the area of contact. The conversation also touches on the implications of torque in spinning scenarios, concluding that while friction remains constant, torque plays a significant role in the dynamics of spinning motion.
  • Understanding of basic physics concepts, including force and friction.
  • Familiarity with the equation F = μN, where N is the normal force.
  • Knowledge of torque and its relevance in rotational motion.
  • Basic grasp of Lagrangian mechanics and Euler-Lagrange equations.
  • Study the relationship between contact area and friction in different materials.
  • Explore the concept of torque in rotational dynamics, particularly in spinning objects.
  • Investigate the role of energy loss in frictional forces during motion.
  • Learn about the Euler-Lagrange equations and their application in analyzing motion.
Physics students, mechanical engineers, dancers interested in the mechanics of movement, and anyone studying friction in rotational dynamics.
James_Frogan
Hey guys, this is not so much a homework question as it is a thought that I'm pondering.
If we have a dancer that is spinning on her toes (wherein she is wearing a metal shoe with a very very very sharp tip) with her CG located above that tip, what is the contact friction?
F= mu_k*N (where in this case N=mg)
I'm wondering if an infinitesimally small point will give 0 friction force?
in which case in reality, the point of rotation has a certain contact area (say 0.01mm^2 radius) with the normal force as mg/area?
Cheers for all the help ;)
Hi James! :smile:
The force of friction is the same, whatever the contact area.
However what matters here is the loss of energy, which is the work done by the friction force …
work done = force times displacement, and the narrower the area of contact, the smaller the displacement (when spinning on the spot) …
so the skater's loss of energy will be proportional to the width of the area of contact. :wink:
Thanks for your answer tiny-tim,
What do you mean by the force of friction is the same, whatever the contact area? If a car brakes and has tiny wheels, shouldn't it have less stopping force? (I can see where you're coming from with the formula, but I am wondering why it is so)
Hi James! :smile:
It just is.
The force of friction depends only on the normal force …
that doesn't depend on the area of contact, so neither does the friction. :wink:
(For rubber, it's slightly different, for reasons I forget but which have to do with the deformation of the rubber … you can look that up! :wink: … but that probably wouldn't apply to the base of a dancer's shoe.)
Oh wow that's interesting. So effectively I can slide an object with 3 sharp points of contact and another with equal mass but 15 points of contact and it wouldn't make a difference if they are all rigid? And it doesn't matter if it's spinning or translating?
For friction in Lagrangian equations, (or Euler Lagrange,) the nonconservative force for the friction in the spinning shoe is (mu)*m*g? [no cos(theta) because of the gyroscopic forces]
Yup! :smile:
except they'd better not be sharp, or they'll dig in and change the coefficient … keep them smooth but small!
dunno, pass :redface:
Hi guys
Well i have read this thing at many places --- The force of friction don't depend on contact area ----
but i still have some doubt. because i just did this with by book, on the flat base i felt that i have to apply more force to make it move. but when on the smaller, force was less!
And can anyone tell me the origin of static friction?
you're probably digging the book in at the edge
alternatively, the coefficient of friction may be different on different sides … perhaps you should use two identical books, first side-by-side, then one atop the other? :wink:
hmm … start a new thread! :redface:
Hi cupid.callin,
My guess (from what I've been reading) is that because in the theoretical we assume that the contact is perfectly flat. However in reality, for an object with a larger surface area, there will be more microscopic pimples/dimples/ridges that lock together with the contact surface.
tiny-tim, I saw your comment before on the Euler-Lagrange equations so I thought you might be able to answer :P perhaps the question is more like: "so in formulating the equations of motion of the spinning dancer, the spinning friction force is just F=umg without any dependence on spin rate?"
Hi James! :smile:
(have a mu: µ :wink:)
Yeees, the force is just µmg …
but what matters in spinning is the torque. :wink:
So in reality, friction does depend on the surface area ??!
tiny-tim, oh dear. Physics is so mean to me :ρ now τorque comes in. Haha. Isn't torque irrelevant if it's spinning on a tip? (or perhaps just close to zero)
It's nearly irrelevant …
does that make you feel better? o:)
ψε∫ thank you! hahaha :P no really, you've been a great help :D thanks!
