Spring constant and conservation of energy
6 replies · 6K views
Knfoster
The ball launcher in a pinbgall machine has a spring that has a force constant of 36 N/cm. THe surface on which the ball moves is inclined theta=10.1 degrees with respect to the horizontal. If the spring is initially conressed 4.25 cm, find the launching speed of a .120 kg bawhen the plunger is released. Friction and the mass of the plunger e negligible.
PE=.5k(xf-xi)^2
KE=.5mv^2
I'not sure what launching speed is supposed to be, it supposed to be an answer that doesn't require units. Does that mean I need to be finding the spring constant? If so, do I just set the KE=PE?
They give you the spring constant. 36 N/cm.
So think conservation of energy.
Spring potential depressed = kinetic energy at release point plus additional increase in gravitational potential energy at release point .
The force constant is the spring constant. You're looking for a velocity.
Think about it if we compress a spring at some angle we are storing potential energy in the spring, but we also have to take into account gravity, does this help?
It can't be simply velocity that I'm looking for because an answer not requiring units is needed. Any other ideas?
I'm pretty sure it's got units -- it asks for the launching speed. Speed's have units of distance per time.
I know... it should but, I'm doing homework through lon-capa and it's telling me that it doens't require units, so it can't be asking for velocity.
