(Spring constant) I can't figure out what I did wrong.
The discussion revolves around calculating the spring constant for two springs in series with a mass attached. The initial approach incorrectly applied conservation of energy, leading to an erroneous factor of 2 in the numerator of the spring constant formula. The correct method involves using the definition of spring constant, K = F/Δx, which simplifies to K = mg/(x1+x2). Participants clarify that the system's stationary state requires consideration of additional forces to prevent oscillation, which were overlooked in the original calculation. The correct formula for the series spring constant is ultimately confirmed as (k1k2)/(k1+k2).
Winvoker555
Two springs which have spring constant of k1 and k2 respectively are vertically hung in a series. Then, a mass m is attached to the end. Find the displacement and the spring constant of this series.
I got the displacement x1+x2 right (which is equal to mg/k1+mg/k2).
Then, I solved for the series constant by using the conservation of energy ,and let the two springs be my system.
ΔUs = Wext
ΔUs = mg⋅(x1+x2)
k(x1+x2)2 / 2 = mg(x1 + x2)
k(x1+x2) / 2 = mg
k = 2mg/(x1 + x2)
Since x1+x2 = mg / k1+mg / k2) ,then:
k = 2mg / (mg / k1 + mg / k2)
k = (2k1k2) / (k1+k2)
I checked the solution and this is not correct (the correct answer is (k1k2) / (k1+k2) );also, I know that the formula for spring constant of a series of two springs is 1 / kseries = 1 / k1 + 1 / k2. However, I can't figure out what I did wrong and what caused the extra 2 factor in the numerator.
ΔUs = Wext
ΔUs = mg⋅(x1+x2)
k(x1+x2) / 2 = mg
k = 2mg/(x1 + x2)
Why do you calculate the new spring constant from conservation of mechanical energy ? If you connect a mass to the end of the new spring and let it go, both the kinetic energy and the elastic energy of the spring would change.
Use simply the definition of spring constant K=F/Δx=mg/(x1+x2).
Likes Winvoker555
Thank you very much for pointing that out. I used conservation of mechanical energy because the problem stated that the system is stationary ,and I thought that I can solve for k this way. However, I now realize that if a mass m is hung at the end of the springs, there has to be an additional force acting on it to stop the oscillation ,and that will caused additional external work that I didn't include in my equation.
You are right now. :)
  • · Replies 19 ·
12K
  • · Replies 17 ·
24K
