Spring constant k, car to rest
2 replies · 12K views · last reply
len2
What should be the spring constant k of a spring designed to bring a 1440 kg car to rest from a speed of 111 km/h so that the occupants undergo a maximum acceleration of 5.0 g?
____N/m
F=-kx
F=ma
V2=v(initial)2 + 2a(x)
v=v(initial) + at
a=5 x 9.8 = 49
F= 1440 x 49 = 70560
x= 30.83^2 +2(-49)x = 9.7
F/x= k =70560/9.7 = 7274.23
Your reasoning looks correct. Is there a problem you were having or did you just need a check on your method?
____N/m
F=-kx
F=ma
v=v(initial) + at
a=5 x 9.8 = 49
This is mostly correct, however the equation vfinal2 = vinitial2 + 2ax is based upon the acceleration (or deceleration) a being constant over distance x. In the case of a spring the force F is proportional to the deflection, F = kx, so the F and the resulting acceleration will vary with distance,
F = ma = kx or a = (k/m)x.
The maximum acceleration occurs at maximum deflection, and in this problem the maximum or limiting acceleration is 5g (or ~ 49 m/s2).
There are two parameters which one must find in this problem, one is the spring constant and the other is the maximum deflection which is not given. One needs two 'independent' equations to solve for two parameters.
Now to finish the problem, find the 'average' acceleration which gives 0 for x=0, and 5g for x = d, where d is the maximum or total displacement of the spring. So, if a(x) = 0, and a(d) = 5g, and a is linear in x, then the average a is just the arithmetic average <a> = 5g/2, or the average a = <a> = amax/2. Then one can use
vfinal2 = vinitial2 + 2ad, where d is the distance over which the average a is applied.
or realizing the previous equation is a form of the conservation of energy, one can realize that the initial kinetic energy of the car must be transformed into the mechanical potential energy stored in the spring at full deflection, i.e.
1/2 mv2 = 1/2 k d2, or
mv2 = k d2.
Using Fmax = m amax = k d, find d and substitute it into the other equation.
Here is a handy reference - http://hyperphysics.phy-astr.gsu.edu/hbase/mot.html
http://hyperphysics.phy-astr.gsu.edu/hbase/acons.html
