Spring Mass Damping System Question? Maximum acceleration?
3 replies · 5K views · last reply
Someone121
Spring Mass Damping System Question?? Maximum acceleration??
Hello,
I was wondering if anyone knows how to go about answering these type of questions...
Anti-vibration mounts are used to attach an instrument of mass 5kg to a panel. The panel is vibrating with an amplitude of 1mm at a frequency 30Hz.
Determine
a)the stiffness of the mounts which provides an isolation effect, i.e a reduction in the vibration amplitude of the attached instrument...
b)the maximum acceleration to which the instrument is exposed when the mounts have an effective stiffness of 30kN/m and also provide viscous damping with a damping coefficient of 60Ns/m
c)the acceleration amplitude of the instrument at resonance
Given MF= X/Y = √( (1 +(2zr)2)/((1-r2) 2 + (2zr)2) )
where X- instrument amplitude of vibration
Y- panel amplitude of vibration
r- frequency ratio
z- damping ratio
MF- magnification factor
We have the following equations
Critical Damping Coefficient cc = 2√km = 2mωn
Equations
f = ωn / 2*(pi)
ωn = √k/m
cc = 2√km
z = c/cc
ωd = ωn√(1-z2)
Solutions
a) Post 3 for solution
b) Post 4 for solution
c)??
Your method for the first one is correct.
For the second part I think you can just use amax = ω2Xmax.
Here is the solution for part a, its just that we have to take into consideration that r > √2 otherwise no isolation
a) For isolation to happen r > √2
Now r = ω/ωn
Now forced frequency ω = 2(pi)f = 2*pi*30 = 188.49 rad/s
so for r > √2
ω/ωn > √2
ω/√2 > ωn as ω =188.49
188.49/√2 > ωn
133.28 > ωn now if ωn = √(k/m)
133.28 > √(k/m) where m =5 kg
133.28 > √(k/5)
133.282 > (k/5)
17764.2 > (k/5)
5*17764.2 > k
88826>k for isolation
88821 N/m >k
also thanks rockfreak your right about that,
any ideas about part c...
Now the solution for b)
f = ωn / 2*(pi)
ωn = √k/m
cc = 2√km
z = c/cc
ωd = ωn√(1-z2)
Therefore we can get
ωn = √k/m = √30*103/5 = 77.45 rad/s
And from above equations we can derive that
z = c/cc = c/2mωn
We are given damping coefficient of 60 Ns/m
therefore z = 60/2*5*77.45 = 0.077459
and r = ω/ωn = 188.49/77.45 = 2.43
Now putting these values in the magnification factor equation we can derive the amplitude X of the instrument therefore
Given MF= X/Y = √( (1 +(2zr)2)/((1-r2)2 + (2zr)2) )
So
X/Y = √( (1 +(2*0.077459*2.43)2)/((1-2.432)2 + (2*0.077459*2.43)2) )
X/Y = √(0.04717 ) now Y = 0.001
therefore X = 0.0002172m
Now if maximum acceleration
amax = Xω2 = 0.0002172 * 188.492 = 7.71 m/s2
