Spring response to sinusoidally varying force
The discussion revolves around modeling the response of a spring, fixed at one end, to a sinusoidally varying applied force. Participants explore analogies between mechanical systems and electrical circuits, particularly in the context of harmonic motion and reactance.
  • One participant questions whether a spring can be modeled similarly to a capacitor, suggesting that the velocity of the spring may lead the applied force by 90 degrees, proposing a model of k/j(omega) for the spring.
  • Another participant introduces the concept of complex harmonic motion and relates it to linear time-invariant (LTI) system theory, indicating that the spring's response can be analyzed using principles from this theory.
  • A participant suggests that the mass can be modeled as j(omega)m, indicating that the velocity lags the applied sinusoidal force by 90 degrees, contingent on the steady-state sinusoidal conditions.
  • One participant emphasizes the importance of resonance, noting that resonance requires both mass and spring in mechanical systems, analogous to capacitor and inductor in electrical circuits.
  • Another participant argues for the ideal case of a massless spring, suggesting that it should be modeled as a simple ideal capacitor, and reiterates that resonance occurs only with two elements present.
Participants express differing views on whether the spring should be considered with mass or as massless, and whether it can be modeled directly as a capacitor. The discussion remains unresolved with multiple competing views on the appropriate modeling approach.
Participants reference the need for steady-state sinusoidal conditions for their models to hold, and the discussion highlights the dependencies on assumptions regarding the mass of the spring and the nature of resonance in mechanical versus electrical systems.
sridhar10chitta
Can one model how a spring (fixed at one end) responds to a sinusoidally varying applied force ? For example, in electric circuits, the reactance of a capacitor is modeled as 1/j(omega)C and is used to obtain the current when a sinusoidally varying voltage is applied.
The hyperphysics link referred by dlgoff shows a mass attached to the spring. If one were to model simply the spring without the mass, and apply a force that varies sinusoidally with respect to time then, can it be that the velocity leads the applied force by 90 degrees ? In which case will it be right to model the spring as k/j(omega) where k = spring constant ?
When a capacitor, modeled as 1/j(omega)C, is subjected to a sinusoidal input voltage, the current in the circuit leads the voltage (input voltage which is equal to the voltage across the capacitor) by 90 degrees. This is a consequence of the fringe field that develops across its plates as charges accumulate on its plate and which opposes the effect of the driving input voltage (field).
sridhar10chitta,
dlgoff's post seems to address your question (as I understand your question).
What you describe is a special case of complex harmonic motion.
In your analog equivalent of the reactance of a capacitor your spring establishes one input to the system (say; y-axis) with harmonic properties fixed by its physical characteristics while another input to the system (also in the y-axis) is your "sinusoidally varying applied force".
A more general expression which would apply in your case (where inputs to the system are coaxial, linear and time invariant) might be found within LTI system theory, see;
http://en.wikipedia.org/wiki/LTI_system
from above link;
"Any system that can be modeled as a linear homogeneous differential equation with constant coefficients is an LTI system. Examples of such systems are electrical circuits made up of resistors, inductors, and capacitors (RLC circuits). Ideal spring–mass–damper systems are also LTI systems, and are mathematically equivalent to RLC circuits."
So we can model the spring as k/j(omega), I take it. Then, as an extension of the inductance case, can one model the mass as j(omega)m where m is a mass ? In which case the velocity lags the applied sinusoidally varying (of course, again, because our notations for the impedance are valid only in the case of steady-state sinusoidal quantities) force by 90 degrees ?
A spring with a spring constant k (e.g., F = -kx) and an attached mass m at the end has a natural resonant frequency:
Fres = (1/2 pi) sqrt(k/m).
This means that you will need something in your circuit that has a resonant frequency; such as a capacitor AND an inductor.
Bob S
I think you are assuming the spring has mass. In the ideal case, the spring is taken to be massless and so the idea that the spring be modeled as a simple ideal capacitor. Resonance occurs only when there are two elements (mass and spring in the mechanical case and capacitor and inductor in the electric circuits case) with a natural frequency of vibration.
The mass is modeled separately as I indicated in my previous posting.
  • · Replies 45 ·
14K
