Springs and dampers in series and parallell
  • Thread starter Thread starter MannyPacquiao
    Series Springs
The discussion revolves around the behavior of springs and dampers in series and parallel configurations, particularly focusing on a system where springs and dampers are connected in parallel and how they can be simplified when analyzing points X and W. The original poster seeks to understand if the system can be represented as a single spring and damper.
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore whether the dynamics between points X and W can be simplified into a single spring and damper system. There are attempts to relate the behavior of dampers to that of springs in terms of series and parallel configurations.
The discussion includes various attempts to clarify the relationships between the components, with some participants questioning the validity of simplifying the system. There is an ongoing exploration of the implications of mass and damping in the context of the original problem.
Some participants express uncertainty about the behavior of dampers compared to springs in series and parallel arrangements. There are references to the importance of free body diagrams and the need for clarity in reference frames when analyzing such systems.
MannyPacquiao
Ok here it goes, we all know that 2 springs in series (k1, k2) can be expressed as one spring with spring constant k using the following equation.
[itex] k=\frac{1}{\frac{1}{k_{1}}+\frac{1}{k_{2}}}[/itex]
The same holds for 2 dampers c1 and c2.
[itex] c=\frac{1}{\frac{1}{c_{1}}+\frac{1}{c_{2}}}[/itex]
But what would happen if we have the system shown in the attached file. Point X is connected to S via a spring k1 and damper c1 in parallell, and point S is conncted to W via a spring k2 and damper c2 in parallell.
My question: If I'm only interested in points X and W, can the system be simplified into a one spring and one damper system?
Already stated
My initial guess is that the dynamics between X and W can be expressed with one spring and one damper with contants
[itex] k=\frac{1}{\frac{1}{k_{1}}+\frac{1}{k_{2}}}, c=\frac{1}{\frac{1}{c_{1}}+\frac{1}{c_{2}}}[/itex]
For this perticular question the masses are irrelevant, however in my original problem X and W have masses but S is massless.
Thanks in advance
Hi MannyPacquiao,
Do you already have the solution and if so can you share it with me. I am also interrested in the answer!
Dirk-Jan.
Sorry I still don't know
Bump.
I've come across the same problem. I'm trying to model almost the same system in Simulink - does anyone know if a series of two damper + spring can be substituted by one damper parallel to one spring, as shown above?
Thanks in advance.
Edit: I'm thinking that two dampers in series have their damping coefficient added, similar to electrical resistance?
Please could anyone confirm that dampers behave the same as springs when they are in series and parallel?
Thanks in advance.
Thanks in advance.
dampers behave the same as springs when they are in series and parallel? Yes.
Are such formulas useful? No! Always construct free body diagrams with well-defined inertial/non inertial reference frames.
Look up 'mechanical impedance'. The standard MKC model is useful only because it leads to compact theoretical solutions, so they are good for an initial/undergrad study.
For a better understanding of what's up with springs and dampers in assorted combinations, first brush up on the reference frame concepts on physics. Then consider that force from damping is proportional to the velocity of the end plates of a damper. So, the force is proportional to the relative velocity of one plate with respect to the other.
The analogy with a spring is, the force from spring is proportional to the displacement of one end of the spring relative to the displacement of the other end. So as long as you keep track of your coordinate systems/state space variables with respect to the reference frames, you will get it right.
Even most advanced graduate level vibrations classes don't talk about it (but professionals do know about it). You can't usually derive theoretical solutions for such problems, so it's left for a quick mention, or none, in chapters dealing with numerical modeling/modal analysis.
Regards,
Sid/sshzp4
Hi,
Can anyone help me formulate the equivalent spring and damper coefficients, for the problem represented on picture below.
Can i just use the equations from the first post in this thread (only instead of using two springs in series, i would use three), or would that be wrong?
J_R said:
Hi,
I don't believe that an accurate equivalent consisting of one spring and one damper can be made. Consider that in your diagram the spring k1 is not damped at all. If set in motion it would oscillate indefinitely (presuming it has some mass or a mass attached to it). Your suggested equivalent has the whole spring damped, so it cannot achieve that behavior.
Thank you Mentor for your reply. It looks like I will have to define d1 as well.
