Calculating $2\sqrt{2}$ to Infinity
  • Context: MHB
  • Thread starter Thread starter maxkor
    Infinity
The discussion focuses on calculating the expression $2\sqrt{2\sqrt[5]{2\sqrt[8]{2\sqrt[11]{2 \cdots}}}}$, which can be represented as $P = 2^{1+\frac{1}{2}+\frac{1}{2\cdot5}+\frac{1}{2\cdot5\cdot8}+\frac{1}{2\cdot5\cdot8\cdot11}+\cdots}$. The participants explore the convergence of this series, with Mathematica indicating that it does not converge. The series defined by the recurrence relation $(3n + 2)a_n - a_{n - 1} = 0$ presents significant challenges in both solving and summing, highlighting the complexity of the problem.
  • Understanding of infinite series and convergence
  • Familiarity with logarithmic properties and transformations
  • Basic knowledge of recurrence relations
  • Experience with computational tools like Mathematica
  • Study the properties of infinite series and their convergence criteria
  • Learn how to manipulate logarithmic expressions in mathematical proofs
  • Research recurrence relations and methods for solving them
  • Explore advanced features of Mathematica for series summation and convergence analysis
Mathematicians, students studying advanced calculus, and anyone interested in the convergence of infinite series and recurrence relations.
maxkor
Calculate $2\sqrt{2\sqrt[5]{2\sqrt[8]{2\sqrt[11]{2 \cdots}}}}$.
I know only that $...=2^{1+{1\over2}+{1\over10}+{1\over80}+{1\over880}+\ldots}$
In order to answer that we will need to know exactly how the exponent are calculated. You have roots of 1, 2, 5, 8, 11. But what next? I don't see any obvious pattern.
14,17,...
Really? I saw that 2+ 3= 5, 5+ 3= 8, 8+ 3= 11 but 1 to 2 does not fit that.
If you want:
calculate $2\ \cdot \ \sqrt{2\sqrt[5]{2\sqrt[8]{2\sqrt[11]{2 \cdots}}}}$.
2 * "that sqrts"
So you need
[math]2 \sqrt{2} \sqrt{ \Pi _{n = 0}^{\infty} 2^{1/(5 + 3n)} }[/math]
I have no proof but Mathematica says this does not converge.
-Dan
No,
[math]2 \sqrt{2} \sqrt{ \Pi _{n = 0}^{\infty} 2^{1/(5 + 3n)} } \neq 2^{1+\frac12+\frac1{2\cdot5}+\frac1{2\cdot5\cdot8}+\frac1{2\cdot5\cdot8\cdot11}+\cdots}[/math]
Yes, I was reading that wrong.
Okay, I can't finish it but I can get it started.
[math]P = 2\sqrt{2\sqrt[5]{2\sqrt[8]{2\sqrt[11]{2 \cdots}}}}[/math]
[math]P = 2 \cdot 2^{1/2 + 1/2 \cdot 1/5 + 1/2 \cdot 1/5 \cdot 1/8 + 1/2 \cdot 1/5 \cdot 1/8 \cdot 1/11 + \text{ ...}}[/math]
[math]ln(P) = ln(2) + \dfrac{1}{2} ln(2) + \dfrac{1}{2} \cdot \dfrac{1}{5} ln(2) + \dfrac{1}{2} \cdot \dfrac{1}{5} \cdot \dfrac{1}{8} ln(2) + \dfrac{1}{2} \cdot \dfrac{1}{5} \cdot \dfrac{1}{8} \cdot \dfrac{1}{11} ln(2) + \text{ ...}[/math]
[math]ln(P) = ln(2) \left ( \dfrac{1}{2} + \dfrac{1}{2} \cdot \dfrac{1}{5} + \dfrac{1}{2} \cdot \dfrac{1}{5} \cdot \dfrac{1}{8} + \dfrac{1}{2} \cdot \dfrac{1}{5} \cdot \dfrac{1}{8} \cdot \dfrac{1}{11} + \text{ ...} \right )[/math]
So we have the form
[math]ln(P) = ln(2) \left ( \sum_{n = 0}^{ \infty } a_n \right )[/math]
where [math]a_n = \dfrac{ a_{n - 1} }{3n + 2}[/math], with [math]a_0 = \dfrac{1}{2}[/math]
The trouble is that the series is neither arithmetic nor geometric. The defining recurrence is [math](3n + 2)a_n - a_{n - 1} = 0[/math] and I have never solved one of these before. (I don't even know how to get Mathematica to solve it.) And the, once you get [math]a_n[/math] you still have to sum it.
This is a highly non-trivial problem for a specific value of n. There may be a way to make it simpler in the limit as n goes to infinity.
-Dan
