Finding the Centroid of an arc, and then of a sector, with heuristic arguments
  • Thread starter Thread starter etotheipi
    Arc Centroid
The discussion revolves around finding the centroid of an arc and a sector, focusing on the mathematical reasoning involved in deriving expressions for the center of mass. Participants explore the implications of changing the shape from an arc to a sector and the associated calculations.
  • Participants discuss the setup of the problem, including the placement of the radius along the x-axis and the integration of small sectors. There are attempts to derive expressions for the centroid using different approaches, including considering small angles and the shape of the sector.
Some participants have offered guidance on correcting assumptions about the shapes involved, particularly regarding the transition from rectangles to triangles in the calculations. There is an ongoing exploration of how to integrate arcs to derive results for sectors, with various interpretations being considered.
Participants note the importance of notation in calculus, discussing the use of ##\delta## versus ##\Delta## and ##d## in the context of small changes and infinitesimals. There is a recognition of differing conventions between physics and mathematics.
etotheipi
A uniform circular arc of radius ##a## subtends an angle ##2\alpha##. The distance from the centre of the arc to the centre of mass of the arc is a function of ##d = f(\alpha)##. By cutting the arc into two similar arcs, show that ##f(\alpha) = f(\frac{\alpha}{2})\cos{\frac{\alpha}{2}}##.
Then assume that ##f(\alpha) = \frac{A\sin{\alpha}}{\alpha}## to be the correct form for ##f(\alpha)## and derive that ##d## for a lamina in the shape of a sector of a circle is ##\frac{2a\sin{\alpha}}{3\alpha}##.
N/A
The first part is not a problem, I let one radius lie along the ##x## axis and then we can write down
##S_x = \frac{M}{2}f(\frac{\alpha}{2})\cos{\frac{3\alpha}{2}} + \frac{M}{2}f(\frac{\alpha}{2})\cos{\frac{\alpha}{2}} = Mf(\alpha)\cos{\alpha}##
from which we can then get the following after using the identity ##\cos{\frac{3\alpha}{2}} = 4\cos^{3}{\frac{\alpha}{2}}-3\cos{\frac{\alpha}{2}}##,
##f(\frac{\alpha}{2})\left[\frac{\cos{\frac{3\alpha}{2}}+\cos{\frac{\alpha}{2}}}{\cos{\alpha}}\right] = 2f(\alpha) \implies f(\alpha) = f(\frac{\alpha}{2}) \cos{\frac{\alpha}{2}}##
It's the second part that's tripping me up. We're now considering a sector which I set up such that the radius again lies along the ##x## axis. The fact that it is a sector does not change the general form of ##f(\alpha)## since we could just replace linear density with area density in the above working.
I consider an arbitrarily small sector of width ##\delta \theta## at an angle ##\theta## from the ##x## axis such that the centre of mass is ##\frac{a}{2}## from the centre of the sector. I can write the expression for ##\delta S_x## (using areas for simplicity) and then integrate from ##0## to ##2\alpha##,
##\delta S_x = \frac{a}{2}\cos{\theta} \times \frac{\delta \theta}{2} a^2##
##S_x = \frac{a^3}{4}\sin{2\alpha} = \alpha a^2 \bar{x}##
and then once I have ##\bar{x}## I can just divide by ##\cos{\alpha}## to get ##d##:
##d = \frac{\bar{x}}{\cos{\alpha}} = \frac{a\sin{\alpha}}{2\alpha}##
It's of the right form, but the constant out the front is all wrong. I'm not sure where I've gone wrong; any help would be appreciated. Thanks!
Sure?
haruspex said:
Sure?
Ah. That's it. I'd assumed if you make ##\delta \theta## small enough it approaches a rectangle, but it should actually approach a triangle. I'll try that and see if it works!
Edit: It works, just need to change ##\frac{a}{2}## to ##\frac{2a}{3}##. Thanks @haruspex!
Good - except that you were instructed to derive it from the arc result.
So instead, consider an arc of radius r, thickness dr.
Repurposing the last part for an arc of radius ##r##, I obtain
##\delta S_x = r^2 \cos{\theta} \delta \theta##
##S_x = r^2 \sin{2\alpha} = 2\alpha r \bar{x} \implies d = \frac{r\sin{\alpha}}{\alpha}##
I think what you're hinting at is that we can integrate up these arcs to get a sector. I'll try that! So considering a sector with an incremental bit of arc on the end, we get
$$\int dS_x = \int_0^a \frac{r\sin{\alpha}}{\alpha} \cos{\alpha} \cdot 2\alpha r dr$$ which does indeed give
$$S_x = \frac{a^3 \sin{2\alpha}}{3} = \alpha a^2 \bar{x} = \alpha a^2 d\cos{\alpha} \implies d = \frac{2a\sin{\alpha}}{3\alpha}$$
Thread moved from Precalc homework section.
The usual terminology used in calculus textbooks for a small change in angle is ##\Delta \theta## (\Delta, rather than lowercase \delta). In an integral, the differential ##d\theta## would be used.
That's strange! Had no idea. Is it just because the ##\delta \theta## looks a little bit funny/wonky?
Physicists use notation like that (i.e., with lowercase delta), but I don't know why, even though I studied physics for two years. The ##\Delta x## vs. dx notation is traditional usage.
I remember there was a thread about this a little while ago, I can't remember exactly what the outcome was though! I like having ##\Delta## for a standard finite change in some quantity, ##\delta## for a small variation and ##d## for an infinitesimal. I suppose at the end of the day it's just notation and so long as the meaning is clear it should be okay.
The most common use for ##\delta## in mathematics parlance is in so-called ##\delta - \epsilon## proofs that use the definition of the limit. Each of these represents a small but positive value.
  • · Replies 22 ·
