Standing Waves On Strings: Harmonic and Frequency Problem
2 replies · 4K views
K_Physics
String A is stretched between two clamps separated by distance L. String B, with the same linear density and under the same tension as string A. String B is stretched between two clamps separated by distance 4L. Consider the first eight harmonics of string B. For which of these eight harmonics of B (if any) does the frequency match the frequency of (a) A’s first harmonic, (b) A’s second harmonic, and (c) A’s third harmonic?
Not sure if I correctly solved the problem (hopefully I did =D). Just need someone to check over my work =D. Thanks!
ν = √(T/μ)
ν = ƒλ
L = nλ/2
ν: Velocity
T: Tension
μ: Linear Density
ƒ: Frequency
λ: Wavelength
L: Length
n: nth Harmonic
[/B]
[/B]
Since the tension and linear density on both strings are equal, the velocity is also equal.
Next I solved for the frequency of system B:
ν = ƒλ
ƒ = ν/λ → 1
L = nλ/2, since L = 4L
λ = 8L/n → 2
Subbing 2 → 1
ƒ = νn/8L
First Harmonic of String A:
L= λ/2 ⇒ λ = 2L
ƒ=ν/λ ⇒ ƒa1 = ν/2L
ƒa1 = ƒb
ν/2L = νn/8L
n = 4 (between 1-8)
Second Harmonic of String A:
L= λ
ƒ=ν/λ ⇒ ƒa2 = ν/L
ƒa2 = ƒb
ν/L = νn/8L
n = 8 (between 1-8)
Third Harmonic of String A:
L= 3λ/2 ⇒ λ = 2L/3
ƒ=ν/λ ⇒ ƒa3 = 3ν/2L
ƒa3 = ƒb
3ν/2L = νn/8L
n = 12 (not between 1-8)
Hello. Welcome to PF!
Your work looks correct.
A similar approach is to note that the harmonic frequencies of A are ##f_A = \frac{n_ {_A} \ v}{2L}## while those of B are ##f_B = \frac{n_{_B} \ v}{8L}##.
Show that ##f_A =f_B## implies ##n_{_B} = 4n_{_A}##. Then let ##n_{_A}= 1## for the first harmonic of A, etc.
Thanks for the help! I will try the question both ways =D.
