Starting initial value problems when terms are expressed only in x
metalscot
How should I go about starting the following two problems
solve the following initial value problems
x''-4x=0 ; x(0)=1, x'(0)=0
and
x''-4x'+4x=0 ; x(0)=1, x'(0)=0
Should i use a general solution with the basis m^2-4=0 for problem one and m^2-4x+4=0 for the second?
on Phys.org
and
Yes, if you meant the solutions in form exp(mt), and m^2-4m+4=0 for the second problem.
ehild
ehild
Thanks ehild, do I then use x=1 and and t=0 to find constant A and x'=1 and t=0 to find constant B for both questions?
The general solution is x=A exp(m1t)+B exp(m2t). Use t=0 x=1 to get one equation for A and B, and t=0, x'=0 in x'(t) to get the other equation for A and B. You get two equations, with two unknown, solve for A and B.
ehild
ehild
Working through my first problem x''-4x=0 ; x(0)=1 x'(0)=0
characteristic equation is m^2-4=0
solutions m=+/-2i
so complex solution (e^2it, e^-2it)
since (cos2t, sin2t)
x(t)=Acos2t-Bsin2t
For x(0)=1
1=A-0
so
A=1
x'(t)= -2Asin2t-2Bcos2t
for x'(0)=0
0=0-2B
so
B=0
therefore
x(t)=cos2t
does this seem correct?
The solutions of the characteristic equation m^2-4=0 are real m=±2.
ehild
ehild
Im sorry ehild I am confused by this, does this mean that my A and B constants are correct making x(t) = cos2t a solution?
cos(2t) and sin(2t) are not solutions.
ehild
If one solution to the characteristic equation of a linear differential equation with constant, real, coeficients is the complex number a+ bi, then [itex]y= e^{at}cos(bt)[/itex] and [itex]e^{at}sin(bt)[/itex] are solutions.
In particular, if the real number a (+ 0i) is a root then a solution is [itex]y= e^{at}[/itex].
If the imaginary number 0+ bi is a root then two solutions are cos(bt) and sin(bt). (Of course, complex, including imaginary, roots of an equation with real coefficients always come in conjugate pairs: [itex]a\pm bi[/itex].)
Which case applies here?
the real number is a root, so my solution must be in the form y= e^{at}[/itex]. ?
metalscot said:
the real number is a root, so my solution must be in the form [itex]y= e^{at}[/itex]. ?
Yes, and you have two values for the exponent, the solutions of your characteristic equation m^2-4=0. You have written that already, but you said that the solutions are 2i and -2i, which is wrong. m^2-4=0 is equivalent m^2=4. What are the roots?
ehild
ehild
does the above not mean that -2 and 2 are roots?
So that then m1 and m2 are -2and 2?
Yes, 2 and -2 are the roots.
You got the characteristic equation originally by assuming that the solution of the differential equation x''-4x=0 is of the form x(t)=emt.
The second derivative is x''(t)=m2emt.
Substituting x(t) and x''(t) back into the DE, you get
m2emt-4emt=0,
factoring out the exponent :
(m2-4)emt=0, which can be true for all t if
m2-4 =0.
This is true for m=2 and m=-2, so the solutions of the DE can be written really in the form of x(t)=emt, and we have two independent solutions, x1(t)=e2t and x2(t)=e-2t.
The general solution is a linear combination of these two functions,
x(t)=Ae2t+Be-2t.
Find A and B so that x(0)=1 and x'(0)=0.
ehild
m2emt-4emt=0,
m2-4 =0.
x(t)=Ae2t+Be-2t.
ehild
I think ehild I have finally arrived at the correct solution
when x(t) = Ae^2t + Be^-2t
x(0)=1
Ae^2t + Be^-2t=1
and x'(0)=0
2Ae^2t - 2Be^2t =0
so with simultaneous equations A = 1/2 AND B = 1/2
I arrive at
x(t)=1/2 e^2t + 1/2 e^-2t
I hope you can tell me this is correct?
Yes, it is correct. Nice work! Now solve the other problem.
ehild
ehild
Thank you ehild. I believe I have now managed the other problem, can you confirm the solution to be x(t) = e^2t - 2te^2t
I really appreciate all the help you have given me.
Good, it is the solution! But use parentheses in the exponent!
ehild
Hi,
I too am trying to solve the second of your problems.
I have used the characteristic equation to find ou that m = 2
I have then used the general solution:
x(t) = Ae^m0t + Bte^m0t
This has given me the following:
x(0) = Ae^2t + Bte^2t = 1
Ae^2(0) + B(0)e^2(0) = 1
A(1) + B(0)(1) = 1
A + 0 = 1
Therfore A = 1
For B:
x'(0) = 2Ae^2t + 2Bte^2t = 0
This is where I am getting confused. Plugging in the 0 value for t:
2Ae^2(0) + 2B(0)e^2(0) = 0
2A(1) + 2B(0)(1) = 0
As A = 1
2(1)(1) + 2B(0)(1) = 0
2 + 2B(0)(1) = 0
2B(0)(1) = -2
Now from your final answer I see that A = 1 and B = -2 to give x(t) = e^2t - 2te^2t
When I multiply out the RHS of the above equation does B remain even though it has been multiplied by zero? I can't see this as in the equation to solve A as 1 the B side equals 0 and the sum is the same. I am sure I am missing something obvious but the more I look at it the more clouded it becomes!
ollyfinn said:
Hi,
A(1) + B(0)(1) = 1
A + 0 = 1
Therfore A = 1
For B:
x'(0) = 2Ae^(2t) + 2Bte^(2t) = 0
x(t) = Ae^(2t) + Bte^(2t)
The second term is a product of t and e^(2t), apply the product rule!
x'(t) = 2Ae^(2t) + 2Bte^(2t)+Be^(2t).
ehild
Aah that's it! Thank you very much for your help.
  • · Replies 18 ·
13K
