Why Does Static Electricity Behave Unpredictably in Everyday Phenomena?
This discussion focuses on the behavior of static electricity in everyday phenomena, specifically addressing the electrostatic interactions between charged objects such as balloons, walls, and paint sprayers. When a negatively charged balloon approaches a neutral wall, electrons in the wall are displaced, creating a dipole moment that results in a net positive charge on the wall's surface. The conversation also explores the mechanics of lightning, explaining that negatively charged ions sink to the bottom of clouds due to charge differences, and clarifies the process of earthing, emphasizing that electrons flow through conductors to prevent shocks. Additionally, the role of paint sprayers in charging surfaces is examined, revealing that ions from the spray adhere to the car's surface, imparting charge.
  • Understanding of electrostatic forces and charge interactions
  • Familiarity with atomic structure, including protons, neutrons, and electrons
  • Knowledge of electric displacement and dipole moments
  • Basic principles of lightning formation and earthing techniques
  • Research the principles of electric displacement and its effects on materials
  • Study the physics of lightning, focusing on charge distribution in clouds
  • Learn about earthing systems and their role in electrical safety
  • Explore the science behind paint sprayers and their electrostatic properties
Students studying GCSE physics, educators teaching electrostatics, electrical engineers, and anyone interested in the practical applications of static electricity in everyday life.
StrawberryElf
This is all related to GCSE content, but it doesn't go into enough depth for it to make sense:
When a balloon sticks to a wall after becoming negatively charged, why does the surface of the wall become positively charged? I would assume that the repulsion between negative charges forces the electrons to move, but does this mean that atoms can change their structure? Theoretically, the atom still has the same amount of protons and electrons, so its overall charge is neutral - does this mean that the electrostatic attraction has a very short 'range' and only reaches the surface of an atom? And why is it that the wall that the subatomic particles in the wall move instead of those on the balloon? Is it because charged particles 'stronger' than neutral particles?
Another question I have is regarding lightning. Why do the negatively charged ions sink to the bottom of the cloud - electrons are lighter than protons, so shouldn't it be the other way round? Actually (I just now thought of this)but is it because the ice and water have the same chemical formula and therefore the same amount of electrons and protons, which would mean that the negatively charged ones are heavier because they have the same amount of protons, but more electrons?
Also, with paint sprayers. I understand why you get an even coat, but what confuses me is the fact that the car becomes charged as well. The car was presumably neutral to begin with, so how exactly do the paint sprayers cause the car's particles to become ions?
I am also confused by earthing. I understand that allowing the charge to flow elsewhere will stop it from shocking you, but how does the charge just 'disperse'? My revision guide says that negative ions flow down, and positive ones flow up - if it flows up, wouldn't it just still cause a shock? So if the negative ones flow down, does that mean the Earth is positively charged? I thought it had a neutral charge though, so does it flow down because it has a more positive charge than the ions?
Yes, the electrons in the wall's atoms are found a bit farther away from the balloon than they were before, and the nuclei are a bit nearer. This means the atoms get a small positive charge on the side near the balloon, and a small negative charge on the other side. This is called electric displacement, from which the atoms get a dipole moment.
The range of the electrostatic force isn't important for this. The particles in the balloon move to, but that doesn't make much difference, the electrons are still there. (This is about movements of the order of less than an atom's size. None of the particles move to the other side of the balloon or the wall.)
Also, there are no neutral particles involved. Both electrons and nuclei are charged.
Do you mean a lightning rod or the earthing of an electric plug? In the latter case, no ions flow, just electrons. The earthing is connected to long wires (which run alongside the power wires), which are in turn connected to the ground, which isn't a bad conductor – there is a lot of moisture and electrolytes like sodium and chloride ions. And the ground is large. So no problem with dispersion.
For a lightning rod, keep in mind that it's all about charge differences, so given that the bottom of a cloud is negatively charged, the Earth is positive relatively to the cloud. You can think of negative charges being repelled by the cloud rather than being attracted by the earth; the effect is the same: they flow down.
So you are essentially saying that the electrons go to atoms of the elements within the ground? Yes, I accidentally said ions, when I meant electrons - sorry about that. Also, my issue is to do with earthing(of, for example, refuelling pipes) is that if the atom has had electrons scraped off and gained a positive charge, my book says the electrons flow up - but wouldn't this still mean there is a risk of a spark??
Also, thanks for taking the time to reply ☺
This makes sense, but I still have one slight issue, I thought that atoms were fixed in structure in that they had their nucleus(with protons &neutrons) orbited by shells with electrons. So, just to clarify, are you saying that this can change via electric displacement??
Atoms aren't super rigid. You can compress them. You only need to change the shape of many atoms very slightly to have a net effect at macroscopic scales. The charge on the balloon induces a dipole moment on the wall, which attracts the balloon.
For lightning, look here: http://www.lightningsafety.noaa.gov/science/science_electrication.htm
Not when they are going through the earthing, i.e. a good conductor. You get sparks when charges try going through the air, which is a bad conductor. The air gets ionised by the electricity, and ionised air (plasma) is a good conductor, facilitating the spark. But this won't happen if there is earthing, since that's the easier way for the electrons.
My pleasure :smile:
The paint spray carries ions with it, and when it reaches the car, the ions sit there.
  • · Replies 20 ·
  • · Replies 36 ·
9K
  • · Replies 58 ·
  • · Replies 20 ·
