Static Equilibrium/Torque-Calculating the force required to tip a box
To calculate the force required to tip a uniform crate with a mass of 13.2 kg and a coefficient of static friction of 0.536, the torque about the center of mass must be considered. The applied force at the top of the crate creates a torque that must balance the torque from friction acting at the center of mass. The initial calculation mistakenly neglected the torque from the normal force, which is crucial for determining the tipping point. When the force is applied halfway up the crate, it leads to slipping due to insufficient torque to overcome static friction before tipping occurs. Adjusting the pivot point to account for friction and the normal force will yield the correct force required to initiate tipping.
taloz
Static Equilibrium/Torque--Calculating the force required to tip a box
A uniform crate with a mass of 13.2 kg rests on a floor with a coefficient of static friction equal to 0.536. The crate is a uniform cube with sides 1.21 m in length.
(a) What horizontal force applied to the top of the crate will initiate tipping?
(b) If the horizontal force is applied halfway to the top of the crate it will begin to slip before it tips. Explain.
Fg= mg
Sum of torques=0
Sum of the forces=0
If you apply a force to the top of the crate to initiate tipping the perpendicular distance between that force and the center of mass (my axis of rotation) should be 1.21/2 meters
The force of friction should also act 1.21/2 meters perpendicular of the center of mass (this is a cube after all).
Therefore, if the sum of the torques equals 0,
(1.21/2)*Force = (1.21/2)*Friction
(1.21/2)*Force = (1.21/2)*0.536*13.2*9.8
Force= .536*13.2*9.8
Webassign-- the thing i use to submit my homework online-- tells me that this is incorrect. Can anyone explain what I'm doing wrong to me. Thanks!
Nevermind, i see what the problem is. I'm forgetting to consider torque from the force normal. I'll have to change my pivot point to the area with the friction and Force normal and look at gravity and the force applied.
I multiplied the values first without the error limit. Got 19.38. rounded it off to 2 significant figures since the given data has 2 significant figures. So = 19. For error I used the above formula. It comes out about 1.48. Now my question is. Should I write the answer as 19±1.5 (rounding 1.48 to 2 significant figures) OR should I write it as 19±1. So in short, should the error have same number of significant figures as the mean value or should it have the same number of decimal places as...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
