Static Friction Coefficient of 224 kg Crate on 20.1° Incline
The problem involves a 224-kg crate on a 20.1° incline, requiring a horizontal force of 573 N to initiate movement down the slope. Participants are exploring the coefficient of static friction between the crate and the incline, utilizing concepts from mechanics.
  • Participants discuss calculating the normal force and the effects of the applied horizontal force on the system. There is confusion regarding how to incorporate the horizontal force into the normal force and the components of forces acting along the incline.
Some participants have provided hints regarding the need to analyze force components perpendicular to the incline. There is ongoing exploration of how to correctly apply the forces involved, with multiple interpretations being discussed.
Participants express uncertainty about the correct approach to calculating the normal force and the static friction coefficient, indicating a lack of clarity on how to resolve the components of forces acting on the incline.
samantha.
A 224-kg crate rests on a surface that is inclined above the horizontal at an angle of 20.1°. A horizontal force (magnitude = 543 N and parallel to the ground, not the incline) is required to start the crate moving down the incline. What is the coefficient of static friction between the crate and the incline?
m=224kg
Force applied = 573
F=ma
Force of Friction=(co-eff static friction)*(Normal force)
So I calculated the normal force to be 2063.6N using N=m*g*cos(theta).
Then, I assumed that 573 was the limit for static friction. So the forces would have to equal up to 0 for there to be no acceleration.
Fapp - Ff = 0
573N - 2063N*(coeff. static) = 0
2063N*(coeff. static)/2063N=-573N/2063N
coeff. static = -0.278
I tried both this value and the absolute value and about 7 other values. I've only got three tries left and I have no clue what to do! Any help would be so great! Thanks in advance.
You need to consider the applied force since it will affect the normal force. Hint: To find the normal force, analyze all force components perpendicular to the surface. They must add to zero.
Thanks for your quick reply.
I'm not really sure how to incorporate the applied force into the normal force since it's purely a horizontal force..
Sorry if I'm a bit slow. I'm a chemist.
2063 x coef of static friction is along the plane but 573 is along the horizontal and not along the inclined plane.
One has to find the component of the weight and of the applied force ALONG the inclined plane.
The applied force is horizontal, but the incline is not. Find the components of the applied horizontal force parallel and perpendicular to the incline surface.
Thanks!
To calculate the component of the applied force that was parallel to the incline I did this;
Fapp(x)=573*cos(20.1)
= 538.1N
Applying this to the equation I used previously,
2063.6N*U-538.1N = 0
0.261.
I confidently entered this answer and I was once again rejected. :(
Woops. I used the wrong value. But doing so, I fixed it to the correct one but I was still wrong.
= 538.1N
Looks good.
That equation is incorrect: You're still using the wrong value for the normal force and you are ignoring the component of the weight acting parallel to the incline.
Ohhh you're very right. Thanks so much again!
  • · Replies 28 ·
