Static Friction / Need Help Solving for Theta
The discussion revolves around a physics problem involving static and kinetic friction as a worker pushes a mop. The original poster has successfully solved the first part of the question, which involves calculating the force required to move the mop head at a constant velocity. The second part of the problem requires finding a critical angle θ0 below which the force is insufficient to move the mop head.
  • Participants discuss the differences between static and kinetic friction, with some questioning the original poster's use of kinetic friction in the first part of the problem. There is an exploration of the equation used to find the critical angle θ0, with some participants suggesting that the original poster's calculations may be correct despite the feedback from the homework program.
The discussion is ongoing, with participants providing insights into the friction concepts and questioning the assumptions made in the original poster's approach. Some guidance has been offered regarding the correct application of friction coefficients, but there is no explicit consensus on the correctness of the original poster's angle calculation.
Participants note the importance of distinguishing between static and kinetic friction in the context of the problem. There is also mention of the original poster's reliance on a calculator and the involvement of a physics professor in verifying their work.
DarPodo
In the figure a fastidious worker pushes directly along the handle of a mop with a force F. (Note: For picture, imagine a worker standing in the second quadrant pushing the mop head into the origin) The handle is at an angle θ = 23.58° with the vertical, and 0.30 and 0.22 are the coefficients of static and kinetic friction between the head of the mop and the floor. Ignore the mass of the handle and assume that all the mop's mass m = 0.40 kg is in its head. If the mop head moves along the floor with a constant velocity, then what is F?
Given:
θ = 23.58°
u(static) = 0.30
u(kinetic) = 0.22
m = .4kgI have solved for the first part of the question. My answer (which is verified correct) is 4.35 N.
I have having trouble solving part 2:
Show that if θ is less than a certain value θ0, then F (still directed along the handle) is unable to move the mop head. Find θ0.
Finding the angle for the second part I used:
us*(Fcosθ+(m*g)) - Fsinθ = 0
After using the above equation with my TI-83 solver function my answer was 31.7 deg. My homework answer program (CAPA) said that it was wrong. I then used the quadratic formula and ended up with the same answer. FINALLY, I consulted with my brother, a Physics Professor, and he agreed that all of my work was correct and my answer was good.
So... Can someone spot an error? I used two different methods, received the same answer, and even consulted a Professor (my own Professor does not offer much help).
static friction is not like kinetic friction
for kinetic you can say: [tex]f_{k}[/tex] = [tex]\mu[/tex]k * N
for static it is : [tex]f_{s}[/tex] <= [tex]\mu[/tex]s * N
I know equations.
For part two the question is referring to static friction because the mop is at rest.
Yes, you can't simply say Fs = (uk) * N. Which i see you did
What is part 2 of the question? I don't see it in the original post.
I am embarrassed... I just updated my original post with the trouble I am having.
To solve for part 1 I used Ffriction = us*N
I don't see anywhere in my work where I had static friction = coeff. of kinetic * N
Sorry if I was misleading with my post - I updated it after someone pointed out I had forgot the actual problem I was having.
You did? If it's moving at constant velocity, you should have used uk*N. I think you may have, but recheck your math. Then when you solve for the correct value of F, your method of solving part 2 appears correct. That TI-83 sure came in handy!
handy!
Ugh! Yes you're right, and I used kinetic, not static, for part 1... But I still am curious as to why my result of 31.7 deg is wrong. I was hoping someone could spot something wrong with my equation to part 2.
The 31.7 degree angle with the vertical looks corect to me. That appears to be the angle, at or below which, the 4.35 N force cannot move the mop forward, until it is set in motion by a greater force ( or larger angle), in which case kinetic friction takes over, and the angle can be reduced to 23.58 degrees to keep it moving at constant velocity.
  • · Replies 42 ·
