Statics: a hinge held up by a string with a mass
4 replies · 10K views
bfusco
A uniform beam of mass M and length L is mounted on a hinge at a wall as shown in the figure. It is held in a horizontal position by a wire making an angle (theta) as shown. A mass m is placed on the beam a distance from the wall, and this distance can be varied.
http://session.masteringphysics.com/problemAsset/1058226/6/GIANCOLI.ch12.p84.jpg
a)Determine, as a function of x, the tension in the wire.
Express your answer in terms of the variables m, M, L, x, θ, and appropriate constants.
b)Determine, as a function of x, the horizontal component of the force exerted by the hinge on the beam. Assume that the positive x and y axes are directed to the right and upward, respectively.
c)Determine, as a function of x, the vertical component of the force exerted by the hinge on the beam.
a)first i realized that the force from the hinge and force due to tension had components.
choosing the hinge for the torque axis of rotation, i used the equation ƩFx=0, Fhx-Tx=0, Fhx=Tx. Then i used ƩFy=0, Fhy+Ty-mg-Mg=0 (here i didn't know what to solve for) and finally i used the equation Ʃτ=0, LT-xmg-(L/2)Mg=0, T=(xmg+(L/2)Mg)/L and it is at this point i don't see how i have yet to solve for anything useful to simplify any of the other equations.
I'm not sure why you would need to solve for anything. Isn't the question simply asking for an equation involving those variables?
yes, but I am focusing on solving for the force due to tension (FT). so i somehow need to work the equations to solve for FT while taking the Fh (force from the hinge) out of the equation. With the Fh in the equation there are 2 unknown variables and that wouldn't be a function of x.
I'm confused, ignore the hinge for the moment if it's your axis. Your equation should be something like the (force of center of gravity)(length acting on) + (force of mass)(length acting on) = (tension on cable)(length acting on). Rearranging that equation, I see no Fh that you speak of.
