Solve for Tension in Equilibrium: Frictionless Rod with 50lb Load at x=4.5
  • Thread starter Thread starter baird.lindsay
    Statics Tension
The discussion centers on solving for the tension in a frictionless rod system with a 50lb load at x=4.5 inches. The correct calculation for the horizontal force P to maintain equilibrium is determined to be approximately 10.98lb, based on the angle of 77.32 degrees derived from the tangent function. The confusion arises from incorrect assumptions about the relationship between tension and the weight, leading to miscalculations. A proper free body diagram clarifies that the tension in line AB equals the weight of 50lb, allowing for accurate application of trigonometric principles to find P.
  • Understanding of static equilibrium principles
  • Proficiency in trigonometry, specifically tangent and cosine functions
  • Ability to draw and interpret free body diagrams
  • Familiarity with tension forces in mechanical systems
  • Study the principles of static equilibrium in mechanical systems
  • Learn how to construct and analyze free body diagrams
  • Explore trigonometric applications in physics, focusing on tension and forces
  • Review examples of frictionless systems in statics problems
Students in engineering or physics courses, particularly those studying statics, mechanical engineers, and anyone involved in analyzing forces in frictionless systems.
baird.lindsay
This is a question from statics course.
Collar A is connected to a 50lb load on a frictionless horizontal rod. Determine magnitude of P to maintain equilibrium when x=4.5.
Im confused on the concept of Tension
I originally got the answer 11.25 lb like the images below but my solution manual is different.
The solution manual says:
tan alpha= 20/4.5 = 77.3 degrees
sum of F sub X=0
-P + T cos 77.3
P= 50lb (cos 77.3)
= 10.98lb (answer manual)
Is this because the tension in the rope is equivalent to the mass of the hanging weight? Is there a way to solve for 10.98lb using method like the one below ...i.e. adding the vector components and solving for the unknowns? confused. Thanks!
but this one below is what makes sense to me.
http://imageshack.us/photo/my-images/15/yci9.png/
Uploaded with ImageShack.us
http://imageshack.us/photo/my-images/534/y53e.png/
sum of x =0
tan=o/a
Your preferred method is correct until you reach the statement:
sin 77.32 / 50 = sin 12.68 / P ---> incorrect statement
If you draw a proper free body diagram of the collar, you will see that the tension in line AB = 50 lb. You know from trigonometry that the horizontal force P must equal 50 * cos a, where the angle 'a' is between line AB and the horizontal, which is 77.32 degrees, when x = 4.5 in.
I am confused because when I draw a free body diagram. I draw it through the center of the collar and move the weight vector to the negative y axis. I have the tension force in the first quadrant , I have the P force on the -x axis , and I have the weight force on the negative y axis.
That doesn't look right because the forces don't add up.. I get T sub x cos 77.32-P=0 and T sub y sin 77.32 - weight =0
If B is a frictionless sheave, then the tension in the line must be the same on both sides of the sheave. Since the weight C of 50 lbs is static, then the tension in line AB must also be 50 lbs. Once this fact is established, then the force P can be worked out using trig, which is determined by the distances given in the setup.
9K
