Stationary Points: (0,0.5) (0,-0.5) (1.25,0) (-1.25,0) Maximum Point
  • Thread starter Thread starter Retro95
    Points
The discussion centers on finding stationary points and determining their nature for the function z = 2x + 5y - 5y² - 5x² - 4xy - 1000. The identified stationary points are (0, 0.5), (0, -0.5), (1.25, 0), and (-1.25, 0). The maximum point is confirmed at (0, 0.5) due to the conditions fxx < 0, fyy < 0, and the determinant fxxfyy - fxy² being positive. Participants emphasize the importance of solving the system of equations simultaneously to accurately identify stationary points.
  • Understanding of partial derivatives and their significance in multivariable calculus.
  • Familiarity with the concepts of stationary points and their classification (maximum, minimum, saddle point).
  • Ability to solve systems of linear equations.
  • Knowledge of the second derivative test for functions of two variables.
  • Study the second derivative test for multivariable functions in detail.
  • Learn how to solve systems of equations using substitution and elimination methods.
  • Explore the implications of mixed partial derivatives in determining the nature of stationary points.
  • Investigate examples of functions with saddle points to understand their characteristics.
Students in calculus courses, mathematics educators, and anyone interested in advanced optimization techniques in multivariable functions.
Retro95
Find the stationary point(s) and also find out whether the stationary point(s) are minimum/maximum
z = 2x + 5y - 5y2 - 5x2 - 4xy - 1000
I'm not 100% sure if I was correct and laid the answer out properly, can someone please help me check it out and correct any mistakes
fx = 2 - 10x - 4y
fy = 5 - 10y - 4x
fxx = -10
fyy = -10
fxy = -4
2 - 10x - 4y = 0, therefore 4y = 2 and y = 0.5
Possible stationary points (0,0.5) (0,-0.5)
5 - 10y - 4x = 0, therefore 4x = 5 and x = 1.2
(1.25,0) (-1.25,0)
fxxfyy-f2xy = 84 (Greater than 0, and fxx & fyy are less than 0 therefore it's a maximum)
(1.25,0) (-1.25,0)
Don't understand the "therefore". You solve fx=0 for x=0 . There is only one solution. Where does the (0, -0.5) appear ?
10x + 4y=2 is the equation for a straight line.
Idem 5 - 10y - 4x = 0. (0, -0.5) does not satisfy that !
What is/are the condition(s) for a stationary point ?
fx = 2 - 10x - 4y
fy = 5 - 10y - 4x
fxx = -10
fyy = -10
fxy = -4
4y = 2 only if x = 0, which you don't know. The equation 2 - 10x - 4y = 0 has an infinite number of solutions.
No, 4x = 5 only if y = 0, which you also don't know.
Solve the two equations simultaneously to find the point or points that are on both lines. If you're in a calculus class, you should know how to solve a system of two linear equations.
(1.25,0) (-1.25,0)
Solving both of them simultaneously I got..
2-10x-4y=0
5-4x-10y=0
Multiplying the top by 4 and the bottom by 10 gives..
8-40x-4y=0
50-40x-100y=0
The x's cancel out, so..
-42+84y=0
84y=42
y=0.5
Subbing y into the original equation makes x=0.12
I've done the main working out, could you please confirm how I would then present the answer
2-10x-4y=0
5-4x-10y=0
You really make it hard on yourself. A little work in advance saves time and minimizes the chance for errors. I would write this system as
10x + 4y = 2
4x + 10y = 5
8-40x-4y=0
50-40x-100y=0
No, but this might have been a transcription error. The first equation should be 8 - 40x - 16y = 0.
Also, it makes more sense to multiply one equation by a positive number and the other by a negative number. Then you can add the equations rather than subtract one from the other.
-42+84y=0
84y=42
y=0.5
Correct, despite the error I noted.
No. You're looking for the solution of the system of equations. Use your y value to find the x value for which fx = fy.
When you have found the critical point, use the other partials to determine whether it's a local maximum, local minimum, or whatever.
Thanks for the help I really appreciate it but if you're going to help me then you might as well help me set out the answer since I've done the main working outs
Since I've concluded that a stationary point is at (0,0.5) and it's a maximum point since fxx & fyy are negative, also because fxxfyy-f2xy is positive. How would I actually present the answer?
Post #2: What is/are the condition(s) for a stationary point ?
You found one point where fx=0 AND fy=0 so that is a stationary point.
Same question for criteria for maximum, minimum, saddle point.
At (0, 0.5), fxx and fyy are both negative, so it is a maximum.
You bring in fxy but I don't see much use for that.
My question: this is homework for a chapter or section in your syllabus or textbook. Don't they summarize these conditions/criteria somewhere ?
Pretty much like what you have above.
The second mixed partials are crucial to overall behavior and cannot be simply dismissed. Having ##f_{xx}, f_{yy} < 0## does not guarantee a maximum; it does eliminate a minimum, but still leaves open the possibility of a saddle point. For example for both functions ## f = -x^2-y^2 \pm 100 xy## the origin is the only stationary point, but is a saddle point rather than a maximum.
Thanks Ray, I learned something. Must have gotten used too much to less pathologic functions! Retro did just fine then.
14K
