Statistical Mechanics: Maximum Entropy
Niles
Hi all.
I've read some about the MaxEnt method (maximum entropy), and one question of mine is still unanswered: Why is it that we wish to maximize the entropy?
When looking at a gas with average energy U, the higher the entropy, the "less" we know about the gas because the multiplicity is high. So how can this "high-entropy" distribution tell us anything about the gas? Wouldn't we want the entropy to be low, so we know which state the particles of the gas is in?
Thanks in advance.
Niles.
You can never know anything about each individual molecule because there are simply too many to follow (about 10^24 in one mole) and their motions and dynamics are rapid and complex. (10^30 coordinates to track when you consider (3 coordinates of position and 3 of velocity). Hence statistical mechanics literally deals with the average behavior of the ensemble of microstates. The individuality making up a microstate is ignored.
Any low entropy state implies a high degree of order that isn't justified by the limited information available to you. Imagine the classical example: why are air molecules evenly distributed in the room you are sitting in instead of being slightly more concentrated in one side? The answer is that there are something like 10^100 more ways to arrange the molecules in the high entropy macrostate, compared to a macrostate that has 1 microjoule lower entropy. (I forget the exact number, but you can look it up or calculate it. It's astronomical.)
From pure combinatorics and probability, you'd be very foolish to assume that the system occupies anything but the maximum entropy state. Thus you always solve for the maxent macrostate.
Ahh, I see. A nice explanation; thanks!
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
