Statistics: independently distributed mean and variance
The discussion revolves around the distribution of overall SAT scores derived from independently distributed math and verbal SAT scores, each following a normal distribution N(500, 10000). Participants explore the implications of assuming independence and the resulting mean and variance of the combined scores.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss the calculation of the overall SAT score based on the assumption of independence, questioning how the overall score is determined (sum or average). They explore the implications of correlation on variance and covariance.
There is an ongoing exploration of how to calculate the mean and variance of the combined scores under different assumptions, with some participants providing guidance on using covariance in the calculations. Multiple interpretations of the problem are being considered, particularly regarding the correlation coefficient's effect on the overall distribution.
Participants note the original problem's lack of clarity regarding the method of combining the math and verbal scores, leading to various interpretations and calculations. The discussion also highlights the importance of understanding the relationship between the two score distributions.
joemama69
Math and verbal SAT scores are each N(500, 10000)
1)If the math and verbal SAT scores were independently distributed, which is not the case, then what would be the distribution of the overall SAT scores? Find its mean and variance.
So originally they are not independent variables, yet the share the same mean and variance. So, if we now assume they are independent, the mean and variance for the two would still be the same, therefore the answer is still N(500,10000). Is this correct?
How is the overall SAT score determined from the math and verbal scores? If it is their sum or their arithmetic average, then NO, you are incorrect.
"How is the overall SAT score determined from the math and verbal scores? If it is their sum or their arithmetic average, then NO, you are incorrect. "
Im not sure I follow... I do not know how the OVERALL scores are determined. I gave the problem word for word as it was given.
Are you saying I should treat it as say...
X = Math where X~N(500,10000), Y = Verbal where Y~N(500,10000)
and then I find E(X+Y) and V(X+Y)?
E(X+Y) = E(X)+E(Y) = 500+500=1000
V(X+Y) = V(X) + V(Y) +2cov(X,Y) where X&Y are independent so cov(X,Y) = 0
... = 10000+10000=20000
Something like that, yes. Assuming that the total score is the sum, otherwise you need to do the corresponding thing to whatever other formula is used.
Ok, thanks...
The question continues...
2) Next assume that the correlation coefficient between the math and verbal scores is .75, Find the mean and variance of the resulting distribution
so... I got .75 = cov(X,Y)/(sigma_x * sigma_y) = [E(XY) - E(X)E(Y)]/(sigma_x * sigma_y)
where x & y are from the same distributions so X = Y...
= [E(X^2) - (E(X))^2]/(sigma_x^2) = V(X)/sigma_x^2 = V(X)/V(X)=1 = incorrect?
That ##E(X) = E(Y)## does not imply that ##E(XY) = E(X^2)## (consider the case where they were independent variables). Instead, I suggest solving for the covariance and inserting it instead of 0 in your original expression in post #3.
So cov(X,Y) = E(XY) - E(X)E(Y)
I looked through my book and searched the web but I do not see how to solve E(XY). I know E(XY) = x*y*p(x,y) but how do I do it when all I know is that X & Y ~ N(500,10000)?
The point is that you do not need to compute E(XY). You have:
as well as
V(X+Y) = V(X) + V(Y) + 2 cov(X,Y)
as well as
I must be missing something... My thought was I solve V(X+Y) for cov(X,Y) and then plug it into my .75 = ... equation.
cov(X,Y) = [V(X+Y) - V(X) - V(Y)] = V(X+Y) - 20000
.75 = [V(X+Y) - 20000]/(sigma_x*sigma_y) = V(X+Y) - 20000/(100*100)
therefore V(X+Y) = .75(10000)+20000 = 27500 I feel like I am off track?
27500 = V(X) + V(Y) + 2 cov(X,Y) = 20000 + 2cov(X,Y)
cov(X,Y) = (27500-20000)/2 = 3750
I don't think I should be using the the "old" variance to find the new mean and variance... how does this end of giving me a new mean and variance
Why? You just computed the variance of X+Y which was the aim ... (although missing a factor of two when solving for the covariance)
The more straightforward way would have been to solve for the covariance first:
0.75 = \frac{{\rm cov}(X,Y)}{\sqrt{V(X)V(Y)}}= \frac{{\rm cov}(X,Y)}{V(X)} \quad \Longrightarrow \quad {\rm cov}(X,Y) = 0.75 V(X) = 7500
It follows that
V(X+Y) = V(X) + V(Y) + 2{\rm cov}(X,Y) = 20000 + 15000 = 35000
Ohhh okay, I don't think I really understood what the question was asking. So the question is asking for the TOTAL or COMBINED score distribution given that correlation coefficient is .75, which is why I solved for V(X+Y).
Soo then what about the E(X+Y), is that simply E(X) + E(Y) = 1000, because the correlation coefficient doesn't really involve the expected values. Probably not the best way of explaining it but am I on the right track.
The expectation value is linear so E(X+Y) is always equal to E(X)+E(Y) regardless of how X and Y are distributed. The reason you are not allowed to do E(XY) = E(X^2) is that, although they are distributed in the same way, X and Y are different stochastic variables. In any given outcome, X and Y may take on different values, while in X^2 the value of X is always fully correlated with the value of X.
