Steam Condensation: Calculating Area for Experiment
The forum discussion centers on calculating the area required for a condensing apparatus in a modified Tesla Turbine experiment. The setup involves condensing exhaust steam from a system operating at 90 PSI through a 1" pipe, with expected exhaust temperatures between 215 to 250 degrees Fahrenheit. The team plans to utilize 8" PVC pipe and a finned copper counter-flow coil, chilled in an ice bath, to achieve their goal of measuring up to 200 pounds per hour of saturated steam. Participants recommend consulting professional engineers for safety considerations and provide a useful reference document for further understanding.
  • Understanding of thermodynamics and heat transfer principles
  • Familiarity with steam properties and condensation processes
  • Knowledge of fluid dynamics, particularly in pipe flow
  • Experience with experimental design and safety protocols
  • Research steam condensation calculations and relevant formulas
  • Learn about the properties of saturated steam at various pressures
  • Investigate the design and efficiency of counter-flow heat exchangers
  • Explore safety measures and risk management in experimental setups
This discussion is beneficial for mechanical engineers, physicists, and experimental designers involved in thermodynamic systems, particularly those working with steam and heat exchange processes.
Gary K
Greetings,
I'm preparing for an experiment on a modified Tesla Turbine design and will need to condense the exhaust steam rapidly in order to measure the pounds per hour of saturated steam that goes through the system. Incoming steam could be as high as 90 PSI through a 1" pipe. As the turbine partially acts as a heat engine, we expect to see exhaust temps in the 215to 250 degrees F range under test conditions. We are wanting to measure up to 200 pounds per hour, but likely will not achieve that input. We are planning on using 8" PVC pipe with a finned copper counter-flow coil, pre-chilled in an ice bath. The question is, how would one calculate the area of the condensing apparatus. We looked into purchasing a vortex mass flowmeter, but the cost is prohibitive for this experiment. Thank you in advance for your input.
Science news on Phys.org
Gary K said:
Greetings,
Hi,Gary. Don't you have a mechanical engineer on your team, or a physicist may be? Here is a useful reference for you to digest. http://www.homepages.ucl.ac.uk/~ucecesf/tmp/heatandpipes.pdf
Thank you very much Ronie. I had not run across this in my searches.
We are still just a two-man team. One of us does have a physics background, but not a degree.
Yap, no problem Gary.
Though, I highly recommend you consult with a professional, especially when there's a lot of risk (life or property) involve in the experiment. Accidents could be avoided, you know.
  • · Replies 26 ·
13K
9K
  • · Replies 44 ·
