Step Function (heaviside) laplace xform
chota
Hi, I currently have this problem to solve and I can't seem to figure it out
it goes like this
Find the Laplace transform of the given function:
f(t) = { 0 t<2, (t-2)^2 t>=2
I tried working it out and this is where i get stuck
f(t) = (t-2)^2 * u(t-2)
I am not sure if I got the write function for f(t), but if I did, I am not sure how to go on with solving this.
Any help is appreciated, Thank YOu
Chota
Did you consider integrating it directly?
The laplace transform of function f(t) is defined as
\int_0^\infty e^{-st}f(t)dt[/itex]<br /> and here<br /> \int_0^\infty e^{-st}(t-2)^2 u(t-2)dt= \int_2^\infty (t-2)^2e^{-st}dt<br /> <br /> and that can be integrated using integration by parts, twice.
it goes like this
Chota
You need to make use of a translation property of the Laplace transform. It states that:
if F(s) is the Laplacetransform of f(t) then L{f(t-a)u(t-a)}=exp(-as)F(s)
Can you apply this to your problem?
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
