What is the limiting factor for the maximum speed of stepper motors?
The maximum speed of stepper motors is primarily limited by the current saturation time in the coils, which can be calculated using Kirchhoff's and Lentz's laws. The theoretical speed derived from these calculations often exceeds the speeds listed in data sheets due to factors such as power requirements and the peak magnetic field necessary for full torque. Additionally, stepper motors are prone to missing steps when operated beyond their rated maximum step rate, particularly during acceleration or deceleration phases.
  • Understanding of Kirchhoff's laws
  • Familiarity with Lentz's law
  • Basic knowledge of electrical circuits, specifically inductors and resistors
  • Concept of magnetic fields in stepper motors
  • Research the impact of coil reactance on stepper motor efficiency
  • Explore methods to optimize current saturation in stepper motors
  • Learn about stepper motor driver configurations for improved performance
  • Investigate torque-speed curves for different stepper motor models
Engineers, hobbyists, and designers working with stepper motors, particularly those focused on optimizing motor performance and understanding electrical characteristics.
liquidFuzz
I was discussing stepper motors with a friend. We touched upon different aspects. I showed how the coils in the motor have a limit to how fast they can be fully saturated with current, and how this time can be calculated by the aid of Kirchhoff's and Lentz's law. The theoretical speed calculated is significantly higher than the speed listed in data sheets for standard stepper motors.
Is there anyone here that know what is limiting the speed for stepper motors?
It depends on how much power you require.
The peak magnetic field is only needed for full torque.
It is probable that the stepper will miss steps when accelerating or decelerating at speeds higher than the rated maximum step rate.
According to my estimate, or approximation might be a better way of describing it, the current saturation time in the coils is:##t = - \frac{L} {R} \ln \left( \frac{U-iR}{U} \right) ##As seen in the model I only consider the electrical behavior of the circuit, i.e a coil L and a resistor R in series. The reactance of the coil might affect the efficiency but probably not account for the difference between this kind of model and the specs in data sheets.
  • · Replies 20 ·
