Stokes theorem, parametrizing composite curves
Gauss M.D.
Calculate the line integral:
F = <xz, (xy2 + 2z), (xy + z)>
along the curve given by:
1) x = 0, y2 + z2 = 1, z > 0, y: -1 → 1
2) z = 0, x + y = 1, y: 1→0
3) z = 0, x-y = 1, y: 0 → -1
I don't think the problem is very difficult when just dividing the line integral into three parts, calculating each separately. But I want to be thorough to see if I got all the concepts.
I tried to draw the curve (see attachment) which made me realize a cone cut in half would be a capping surface, so we should be able to apply Stokes theorem. But I'm having trouble parametrizing it since we've basically dealt exclusively with very standard parametrizations.
I think that one parameter should be the height of the cone, h = [itex]\sqrt{y^{2}+z^{2}[/itex] running from 0 to 1 and the other should be the angle in the xz-plane running from 0 to [itex]\pi[/itex]. I'm just having trouble setting up the variable substitution. Can anyone give me a push?
  • Sketch in 3D perspective of a closed curve: a semicircular arc in the vertical plane through the origin, with two straight segments running from its endpoints to a common point on the horizontal axis, plus gray coordinate axes.
Hi Gauss M.D.! :smile:
Before you spend time trying to apply stokes …
what is the curl? :wink:​
<x-2,x-y,y^2>... you're saying Stokes theorem is a bad idea here?
stokes is useful if the curl is 0, or something simple
which do you think is easier, integrating that curl over that curved surface, or integrating the original line integral directly? :smile:
