- 37,019
- 16,030
SR always applies locally, and the GR version of Newton's laws always applies.
Madness said:I like that point of view too but unfortunately you can still tell whether or not you are in an inertial frame
Madness said:SR only applies when the connection vanishes at that point in spacetime. This is achieved by making a change of coordinates, ie changing to an inertial frame.
You need to be more careful with the terminology. A person or an object never just "is in an inertial frame". What you're trying to say is probably that both his velocity and acceleration are 0 in an inertial frame.madness said:If he's floating, and objects float around him then he is in an inertial frame.
madness said:In other words, if we switch to a frame which is accelerating downwards with respect to him, then events at his space-time point appear to obey the laws of SR, but that for him he is still in a non-inertial frame.
madness said:I don't see how it's a matter of choice and not a matter of fact. If there were no such thing as an inertial frame then the theory would be fully Machian. Then for example the twin paradox really would be a paradox in GR.
I can see that definition, it is not common but it makes sense. Usually when most people talk about SR they just mean flat spacetime; at least that is what I meant by SR always applies locally. But I do understand your point.madness said:SR only applies when the connection vanishes at that point in spacetime. This is achieved by making a change of coordinates, ie changing to an inertial frame.
DaleSpam said:I can see that definition, it is not common but it makes sense. Usually when most people talk about SR they just mean flat spacetime; at least that is what I meant by SR always applies locally. But I do understand your point.
MTW said:Is this the only coordinate system at P0 that is locally inertial at P0 ... and is tied to the basis vectors there? No. But all such coordinate systems, (called 'normal coordinates') will be the same to second order.
pervect said:Note that there may be several coordinate systems through any given point that make the connection vanish. Even if you specify the basis vectors at that point, there are more than one set of coordinates that make the connection vanish.
atyy said:Isn't this the same difference? Roughly identify "connection" with "Christoffel symbols". The Christoffel symbols are first derivatives of the metric and can be made to vanish anywhere in curved spacetime, which is why there is always a "local inertial frame". But the derivatives of the Christoffel symbols, ie. second derivatives of the metric, cannot be set to zero, and so the "local inertial frame" that exists anywhere in curved spacetime only pertains to measurements which do not measure curvature.
Yes, they can be made to vanish anywhere through suitable choice of coordinate system, but there do exist coordinate systems where they do not vanish at any given point. Madness is defining such coordinate systems as locally non-inertial, which is not unreasonable IMO.atyy said:Isn't this the same difference? Roughly identify "connection" with "Christoffel symbols". The Christoffel symbols are first derivatives of the metric and can be made to vanish anywhere in curved spacetime, which is why there is always a "local inertial frame".
They exist, but there's no standardized terminology, and apparently (I didn't know this a few days ago), they aren't unique, and can also be very difficult to write down explicitly, which makes them less useful than I expected. (I hope I got that right. I still don't understand the details).madness said:My lecture notes rely extensively on the concept of a "locally inertial frame", so much so that it is abbreviated to LIF. I would even go so far as to say the course is structured around this concept. This is why it's confusing for me to hear that the concept doesn't exist or isn't useful in GR.
madness said:"They exist, but there's no standardized terminology, and apparently (I didn't know this a few days ago), they aren't unique, and can also be very difficult to write down explicitly, which makes them less useful than I expected. (I hope I got that right. I still don't understand the details)."
Well for any LIF, there are infinitely many other LIF's at that point related by a Lorentz transform. I'm not sure if that's why you mean by unique.
The "L" in LIF is one reason that LIFs are much less central than in Newtonian mechanics. The other reason they're less important is that the laws of GR (unlike Newton's laws) are still valid in coordinates that don't describe an LIF.madness said:My lecture notes rely extensively on the concept of a "locally inertial frame", so much so that it is abbreviated to LIF. I would even go so far as to say the course is structured around this concept. This is why it's confusing for me to hear that the concept doesn't exist or isn't useful in GR.
It's not clear to me whether an example has been given, so let me give one.Altabeh said:Would you mind giving us an example of what you just claimed above?! It sounds completely wrong to me as if you are ready, I'm going to explain it matheamtically!pervect said:Note that there may be several coordinate systems through any given point that make the connection vanish. Even if you specify the basis vectors at that point, there are more than one set of coordinates that make the connection vanish.
DrGreg said:It's not clear to me whether an example has been given, so let me give one.
Let (t,x) be Minkowski coordinates in flat spacetime. (To save typing I'll ignore y and z but you can add them back if you want.) They define an everywhere-inertial frame, not just a locally inertial frame.
Now (with the convention c=1) define new coords T = t − x3/3, X = x in a region around the origin. The inverse transformation is t = T + X3/3, x = X.
The metric is
[tex]ds^2 = dt^2 \, - \, dx^2 = dT^2 \, + \, 2X^2dT\,dX \, - \, (1-X^4)dX^2[/tex]
At any event where X=0, but nowhere else, the metric in (T,X) coordinates takes the Minkowski form, and its first-order coordinate derivatives vanish (and hence the connection vanishes).
Thus (T,X) defines a locally inertial frame but doesn't define an everywhere-inertial frame.
So we have two different locally-inertial frames, which establishes the non-uniqueness claim.
atyy said:Is the question whether Riemann normal coordinates for a given point are unique?
atyy said:I looked up the Riemann normal coodinates construction in Eq (2.35) to Eq (2.35) at http://nedwww.ipac.caltech.edu/level5/March01/Carroll3/Carroll2.html .
Say we want to get RNC at point p. Suppose you start with some non-RNC coordinates x. Any new coordinates y can be specified by arbitrarily choosing the terms A, B, C, D, E,... in a Taylor expansion x=A+By+Cyy+... where A are the 16 first derivatives dx/dy evaluated at p, B are the 40 second derivatives dxdx/dydy evaluated at p, etc.
The new metric G can be Taylor expanded G=Gp+dGp.y+ddGp.yy+... For RNC at p we require Gp=diag(-1,1,1,1) and dGp=0 as constraints on our choice of A,B,C etc. The Gp=diag(-1,1,1,1) are 10 constraints on the 16 numbers A, so they are underspecified. Choosing all 16 numbers I think corresponds to what Pervect meant by "specifying the basis at that point". dGp=0 are 40 constraints on our choice of the 40 numbers in B, which are thus exactly specified. It looks to me like at this point we have constructed an RNC, while C, D, E,... are still unconstrained. So I guess RNC for a point are not unique.
