Strain optic coefficient definition
The strain optic coefficient is defined in terms of stress birefringence, as established by Born and Wolf. It quantifies the relationship between applied stress and induced birefringence in materials. The index ellipsoid of an unstressed material is modified by stress components, leading to a mathematical representation involving optical-stress coefficients. Typical strain optic coefficient values include polyurethane (3-5) and epoxy (60) in pounds-fringes per inch.
  • Understanding of stress birefringence and photoelasticity
  • Familiarity with index ellipsoids and optical-stress coefficients
  • Knowledge of stress-strain relationships in materials
  • Basic principles of crystal optics and acousto-optics
  • Research the mathematical derivation of strain-optic coefficients
  • Explore applications of photoelasticity in material science
  • Study the effects of different materials on birefringence
  • Learn about the use of polarized light in stress analysis
Material scientists, optical engineers, and researchers in the field of photoelasticity will benefit from this discussion, particularly those focusing on stress analysis and birefringence in materials.
Femme_physics
I can't find the THEORETICAL definition of "strain optic coefficient" online. I googled and wiki'd enough. Can someone provide me with one, please?
Science news on Phys.org
Born and Wolf defined stress- and strain-optical constants in terms of stress birefringence (photo-elastic effect). For example, the index ellipsoid of an unstressed material may be written as:
\frac{x^{2}}{\epsilon_{x}}+ \frac{y^{2}}{\epsilon_{y}}+ \frac{z^{2}}{\epsilon_{z}} = 1
and applying a stress \sigma with components \sigma_{xx}, \sigma_{xy}, \sigma_{xz}, etc changes the ellipsoid to:
a_{xx}x^{2}+a_{yy}y^{2}+a_{zz}z^{2}+a_{xy}xy+a_{xz}xz+a_{yz}yz+=1, with the optical-stress coefficients q relating the unstressed and stressed index ellipsoid: for example
a_{xx}-\frac{1}{\epsilon_{x}}=q_{xxxx}\sigma_{xx}+q_{xxyy}\sigma_{yy}+q_{xxzz}\sigma_{zz}+q_{xxyz}\sigma_{yz}+q_{xxzx}\sigma_{zx}+q_{xxxyx}\sigma_{xy}.
Similarly, by using the stress-strain relationship \sigma_{ij} = C_{ijkl}\epsilon^{kl}.. sorry, 'epsilon' got used twice here... you can generate the strain-optic coefficients.
This subject gets covered in various places- crystal optics, acousto-optics, etc.
So, to put things in English :) --> it's the relation between stress and strain of a certain material?
not exactly- it's the relationship between the applied stress and induced birefringence.
Hello again, Femme Physics.
I take it you are now studying photoelasticity?
So you will have seen the striking pictures that photoelastic analysis can generate?
These are alternate regions of light and dark (and sometimes pretty colours) when polarised light is shone through a suitable material undergoing strain. Alternatively if the object is opaque and we coat it with a suitable photoelastic coating then the light passes through the coating is reflected by the substrate and passes back through the coating - a double journey.
Either way the difference in stress between two dark zones, a and b ( is given by the equation
{\sigma _b} - {\sigma _a} = \frac{{CN}}{t}
Where N-1 is the number of dark regions between a and b,
t is the thickness,
C is a material constant which I think (edit: but I am not certain) is your strain optic coefficient.
Typical values are
polyurethane 3 - 5
epoxy 60
pound-fringes per inch (sorry it's imperial)
  • · Replies 29 ·
10K
  • · Replies 19 ·
