Strange constant, rolling cylinders.
The forum discussion centers on the analysis of a strange constant derived from an experiment involving rolling cylinders. The equation used is t = 2√(l/g(1+(r/R))(1/sin(θ)))-0.5, which was linearized using MATLAB. Participants express doubt about the accuracy of the constant, suggesting that it may stem from experimental errors. Clarification on the experimental setup and parameter definitions is requested to resolve the issue.
  • Understanding of rolling motion physics
  • Familiarity with MATLAB for data analysis
  • Knowledge of trigonometric functions and their applications
  • Basic principles of linearization in mathematical modeling
  • Investigate the principles of rolling motion and its equations
  • Learn MATLAB's linearization techniques for experimental data
  • Study the impact of experimental errors on derived constants
  • Explore the relationship between radius (r), radius of curvature (R), and angle (θ) in rolling dynamics
Students and educators in physics, engineers involved in mechanical design, and researchers analyzing experimental data related to rolling motion.
BruceSpringste
We have experimented on rolling cylinders and have gotten the function for a rolling cylinder but have gotten a strange constant from experiment.
t = 2\sqrt{\frac{l}{g}(1+\frac{r}{R})\frac{1}{\sin{\theta}}}-0.5
Is this constant wrong? Which we think it is. We got it from linearisation from matlab. It doesn't make sense and probably is the fault of experiment. Any thoughts?
Can you tell us more about the experiment and define the parameters in your Relevant equation?
  • · Replies 97 ·
