Structure of Matter in Quantum Field Theory
75 replies · 11K views
mitchell porter said:
But you can have deconfinement at high temperatures, and then reconfinement.
In another thread here:
https://www.physicsforums.com/threads/how-can-quarks-exist-if-they-are-confined.958432/
I mentioned that the finite density (and I should also say high temperture) phase of QCD is probably the answer.
However I don't think what these phases mean in quantum field theory is as simple as is often thought, for they lie in a different folio to the normal QCD vacuum. This means that high temperature and high density QCD isn't just a bunch of particles sitting in the normal QCD vacuum and tightly squeezed together and having large kinetic energy.
There's no unitary (or even Louville-VonNeumann) evolution from the normal vacuum sector states to these states.
But it means that there is a family of theories (foilia) parameterized by temperature and density, of which the vacuum sector is just the limit of zero density and temperature. (See also here.) This family of theories is what is called QCD, and since it has quarks and gluons in certain sectors, at least as a kind of quasiparticles, one must be able to account for them somehow even in a rigorous view of QCD.
Thinking a bit about this I was just wondering about its relation to the Unruh effect, perhaps somebody could tell me where I'm wrong.
Let's take an inertial observer and some test object. The inertial observer uses QCD + QED to described the object and thus that it is composed of neutrons, protons and electrons.
However a highly accelerating observer would due to the Unruh effect view the object as being in a Thermal (KMS) state at temperature ##T = \frac{\hbar a}{2\pi ck_B}##. If the temperature is high enough the accelerating observer would have his state be a deconfined quark-gluon plasma state.
So whether something is made of nuclear matter or quark-gluon plasma seems to depend on the observer.
Yes. Observer-independent is only the field. The particle interpretation of the field is frame- and hence observer-dependent - for an abstract observer.
In practice, one cannot observe a test object highly accelerated with respect to an observer - one observes only some mean values of the part of the field it generates that is close to the observer during the observation time. Thus the relevant frame is that of the matter field comoving with the observer.
PeterDonis said:
And even when they do, those notions can be observer-dependent, as illustrated by, for example, the Unruh effect.
This one is tough for me, that what I am made of is observer dependent to some degree. Hard to understand intuitively, at least for me!
No, it isn't; what you are made of is invariant. A description of what you are made of in terms of "particles" might not be--but that's not a problem with what you are made of, it's a problem with thinking that a description in terms of "particles" has to be invariant, when in fact it doesn't.
And what's that if not particles?
[Moderator's note: rest of post removed as it has now been moved to this thread.]
Just to say, this is more to tease this out, I do think (and hope for my intuitions sake!) that you are correct that the fundamental "stuff" things are made of is invariant and it is simply the particle description that is variant. This is more just a question of if that stuff is quantum fields or are quantum fields still just observables with no stronger a claim to be the constituents of matter than the particle observables.
Also of course QFT might be ultimately wrong and there might be another layer beneath it, but let's assume it's as correct as it seems for now.
PeterDonis said:
Short answer? Quantum fields. :wink:
So to sketch this out. Would you say for example that the fundamental constituents of matter involve the pre-symmetry breaking electroweak fields or the post-symmetry breaking electromagnetic and ##W^{\pm}## and ##Z^{0}## fields?
Yes. :wink:
These are not different sets of fields. They are different descriptions in terms of fields. I look at it the same as a change of inertial frames in SR: you're describing the same underlying thing, just in different coordinates. Similarly, symmetry breaking doesn't change the underlying thing, but it does change which description of it is most useful.
PeterDonis said:
Yes. :wink:
Fascinating. And what would you think of the fact that fields don't have well defined values at a point, i.e. ##\phi(x)## is undefined? That the fundamental things are the smeared fields, ##\phi(f) = \int_{\mathcal{M}}{\phi(x)f(x)d^{4}x}##?
Well, since you and I are not point particles, I don't see the problem. :wink:
Seriously, since we never make measurements of anything at an exact point, I don't see the problem. "Smeared fields" seems like a better description of what we actually measure anyway.
Yeah I agree. This would tend to suggest that the fundamental object is really the local observable algebra and that any choice of fields is a particular basis/decomposition of it. That genuinely is invariant and carries the representations of symmetries we expect and is detached from the observer dependent notion of a Hilbert space.
Of course one could ask is this really what I'm made of, or if it simply defines a set of admissible and complementary classical descriptions of what I'm made of (i.e. the old Copenhagen "QM doesn't tell you anything about reality" that you also see in the Consistent histories view). However that's going into interpretations so I won't bother.
Regardless the fundamental thing is the sheaf of local observables.
I would agree.
We are made of matter described by states of a quantum field theory. Just as in classical mechanics we were supposed to be made of particles described by phase space coordinates.
DarMM said:
And what would you think of the fact that fields don't have well defined values at a point, i.e. ##\phi(x)## is undefined? That the fundamental things are the smeared fields, ##\int_{\mathcal{M}}{\phi(x)f(x)d^{4}x}##?
Those ##\phi##'s really need an indication that they're operators, indexed by a set of test functions, ##\hat\phi_f##, which, taken independently of any other observables we can take to represent a random variable, with the vacuum state providing a probability density. We can't measure ##\hat\phi_f## at a point, for ##f## a delta function, insofar as the variance is infinite (or, better, undefined, as you say) even for the free field, but, thinking very loosely, for any finite region an infinite sum of infinite variance random fields can perfectly well be finite and finite variance.
I find it helpful to use signal analysis language, with the test functions performing a function very close to that performed by "window functions" (signal analysis), Chris Fewster calls them "sampling functions" (and perhaps others do, but I haven't seen it from others). In signal analysis terms, we can think of ##\hat\phi_g|0\rangle## as a multiplicative modulation of the vacuum state, so that when a test function is used in this way it's appropriate to call a test function a "modulation function" (so signal analysis again).
In signal analysis terms, there's no a priori reason to think that the (pre-)inner product ##\langle 0|\hat\phi_f^\dagger\hat\phi_g|0\rangle## has to be a linear functional of ##f## and ##g## at all length scales and at all amplitudes, provided it's complex-linear in ##\langle 0|\hat\phi_f^\dagger## and ##\hat\phi_g|0\rangle##, indeed our usual experience of nonlinearity in signal analysis suggests that we should expect it not to be, and yet the Wightman axioms insists it must be (for no physically justified principle), and the Haag-Kastler axioms, to approximately the same effect, insist on Additivity. Loosening this axiom results in a plethora of (what I find) interesting nonlinear models, as a result of which we can naturally construct multi-point operators (by polarization) that can be used to represent bound states (the account I've given here is obviously much too fast: a development that is as good as I could manage a few years ago can be found in arXiv:1507.08299, still very early days yet). FWIW, I see a connection between this account and the discussion in this thread of bound systems, with apparently no resolution, whereas for me this kind of approach offers at the least some possibilities — which, moreover, are moderately principled and empirically grounded in signal analysis concerns.
