Studying the force on a plate from an air jet
The discussion revolves around deriving a theoretical equation for the force exerted on a plate by an air jet, based on a lab experiment. Participants explore various equations and concepts related to momentum and pressure, while also considering the implications of experimental measurements versus theoretical predictions.
  • Experimental/applied
  • One participant suggests using the momentum equation F = m(dot)(v2 - v1) to find the reaction force of the jet on the plate.
  • Another participant confirms that the force of the jet on the plate can be expressed as F = m(dot)v(nozzle), but raises concerns about varying plate height affecting the force.
  • A different participant provides a rearranged equation F = ρA V_0^2 sin(θ) and notes that if the plate is perpendicular to the jet, it simplifies to F = ρA V_0^2.
  • Another approach is introduced, suggesting that force can also be calculated using F = P × A, where P is the pressure of the air jet and A is the area of the tube.
  • A participant inquires about the relationship between theoretical and practical measurements, questioning whether theoretical values are likely to be higher or lower than actual lab measurements.
  • Responses indicate that if theoretical calculations account for all necessary variables, the values should not differ significantly from practical measurements.
  • Concerns are raised about neglecting air resistance in theoretical calculations, with one participant acknowledging that air resistance is indeed a factor in their experiment.
Participants express differing views on the impact of air resistance and the accuracy of theoretical versus practical measurements. There is no consensus on whether the theoretical values should be higher or lower than the measured values, and the discussion remains unresolved regarding the inclusion of certain factors in the calculations.
Participants note the potential neglect of air resistance in theoretical calculations, which may affect the accuracy of comparisons with practical measurements. The discussion also highlights the variability in measurements due to factors like plate height and air jet dynamics.
skaboy607
Hi,
I have been carrying out a lab experiment where I am studying the force on a plate from an air jet. I need to come up with a theoretical derivation of an equation for the force on the plate and I was wondering if anyone had any ideas about how to go about this?
Thanks
skaboy607 said:
Hi,
Thanks
Use the momentum equation to find the reaction force of the jet impinging on the flat plate.
CS
Thanks for replying, the momentum equation that I have is F=m(dot)(v2-v1), however I only have a value for the velocity leaveing the nozzle (v1). Given also is an equation that says the force of the jet on the plate is = m(dot)v(nozzle). Is this correct as what has confused me is that the plate height varies so this would make the force less the further away it got from the jet.
Thanks
skaboy607 said:
...Given also is an equation that says the force of the jet on the plate is = m(dot)v(nozzle). Is this correct as what has confused me is that the plate height varies so this would make the force less the further away it got from the jet.
Thanks
Yes that is the correct equation. Perhaps a little rearrangement would help:
[tex]F = \rho Q_0 V_0 \sin{\theta}[/tex]
and since [itex]Q = VA[/itex] we can substitue and get:
[tex]F = \rho A V_0^2 \sin{\theta}[/tex]
where,
A is the area of the jet striking the plate
V_0 is the initial velocity of the fluid
[itex]\rho[/itex] is the fluid density
[itex]\theta[/itex] is the angle the plate makes with the horizontal
If perpendicular it will be [itex]\sin{\theta} = 1[/itex] and will reduce further to:
[tex]F = \rho A V_0^2[/tex], which is the equation you were given for the lab.
Hope this helps.
CS
U can also calculate the forcce by using,
F=PxA
F=force applied
P=Pressure of the air jet
A=Area of the tube
I know this is from a while back, but still: if anyone gets this: I'm doing a similar problem at the moment, but I also have real values measured in the Lab, is it likely the theoretical values would be higher or lower than the actual values?
Just want to check I'm on the right lines before I go and write an entire report on the wrong thing...
Thanks very much,
Lauren
Well it depends, were the theoretical value calculations negating any values (for example, sometimes you ignore air resistance when doing projectile motion)?
If not, and the equations used detail all required variables, the theoretical values shouldn't be that far off the real values.
Air resistance is neglected.
Well I have values of 10.104 - 10.202 for the practical measurements and 7.167 for the theoretical value. I think the calculations are all right, but will go over the numbers again to check
Air resistance is neglected?
But you're measuring air resistance with this experiment (force of air jet on a plate)?
Ah, good point, well yeah.
Guess it isn't then.
I meant more that I don't know if we're supposed to be including whether the air jet slows down due to the other air particles in the room...It isn't mentioned so I assumed not.
12K
  • · Replies 16 ·
