Substitution homework question
11 replies · 3K views
suspenc3
Hi, I am having a little bit of trouble with the following:
[tex]\int sintsec^2(cost)dt[/tex]
heres what I have so far
[tex]u=cost[/tex]
[tex]du=-sintdt[/tex]
[tex]-\int sec^2(u)du[/tex]
[tex]-2tan(u) + C[/tex]
is this right?
yea but I am integrating..so the antiderivative of sec^2(u) is tanu?
[tex]\int \sec^2 x \; dx = \tan x +c[/tex]
~H
I have another..i don't know where to start..can someone point out what I should sub U for?
[tex]\int_{1/2}^{1/6}csc \pi t cot \pi t dt[/tex]
My first step would be to turn the cosec and cot into sine and cosine. See where that takes you.
~H
ok..so i did..
[tex]\int_{1/2}^{1/6} \frac{1}{sin\pi t) \frac{cos \pi t}{sin \pi t}dt[/tex]
ended up with...
[tex]\int_{1/2}^{1/6} cot \pi t[/tex]
im guessing its wrong haha
suspenc3 said:
ok..so i did..
ended up with...
It's almost there :wink:
[tex]\frac{1}{\sin \pi t} \cdot \frac{\cos \pi t}{\sin \pi t} = \frac{\cos \pi t}{\sin^2 \pi t}[/tex]
Now, see what you can do with the identity [itex]\sin^2 \theta + \cos^2 \theta = 1[/itex]. Btw, I think this can be done without a substitution.
~H
do you mean..sin^2(pi t) = 1-cos^2(pi t)..and then sub?
Forget about the subs.
Try putting sin(pi*t) = x
What is dx ?
[tex]u=cost[/tex]
is this right?
As others have pointed out, the anti-derivative of sec2(u) is tan(u), not -tan(u).
Also, the original problem does not say anything about "u"! That was your "invention". To properly answer the question, you need to go back to t:
[tex]\int sintsec^2(cost)dt= 2tan(cos(t)+ C[/tex]
Actually, the original poster (with respect to the original question) is correct, save for the two.
[tex]\int sin(t) sec (cos(x))^2 dx[/tex]
[tex]u = cos(x) du = -sin(x) dx[/tex] This is right. Substituting back yields
[tex]- \int sec(u)^2 du[/tex] Just as the OP said. The negative sign is the result of the du = -sin(x) dx part.
Now, the antiderivative of sec(x)^2 = tan(x) + C (as everyone as stated)
- ( tan(u) + C)
-tan(cos(x) + C.
The original poster's only error is the two infront. The minus sign is correct . Check with differentiatoin (or use the "Integrator").
