Reviewing Kinematics for AP Physics Exams: When to Subtract Gravity?
This discussion clarifies the treatment of gravitational acceleration in kinematics, particularly in the context of rocket motion. When a rocket accelerates upwards at 5 m/s², this value represents the net acceleration after overcoming gravity, which is 9.8 m/s². Therefore, there is no need to subtract gravity from the upward acceleration when calculating thrust; instead, the thrust must counteract gravity in addition to providing the net upward acceleration. The formula F=ma is essential for calculating the thrust required to maintain this acceleration.
  • Understanding of Newton's Second Law (F=ma)
  • Basic knowledge of kinematics and acceleration
  • Familiarity with gravitational acceleration (9.8 m/s²)
  • Concept of net force and vector sum of forces
  • Study the implications of net force in rocket propulsion
  • Learn how to calculate thrust using F=ma in various scenarios
  • Explore the effects of different accelerations on rocket dynamics
  • Investigate the role of forces acting on objects in free fall
Students preparing for AP Physics exams, educators teaching kinematics, and anyone interested in understanding the principles of rocket motion and forces.
belledona
Member advised to use the formatting template for all homework help requests
Hello, I'm reviewing kinematics for an upcoming AP physics exam, but I seem to have forgotten a crucial fact. In typical rocket problems (when the rocket blasts off with an initial acceleration for example 5 m/s^2), why don't we subtract 9.8 from 5m/s^2 when using a value for acceleration? When do we know to subtract gravity from an upwards acceleration, or to just simply use the value given for the upwards accel w/o subtracting?
The 5 m/s2 is the acceleration upwards, and this should become clear from the way the value is given. If you want to find the thrust or forces acting on the rocket, you'll have to take into account that the rocket has to fight against gravity.
Likes belledona
The value of 5 m/s2 describes the actual motion of the missile. If gravity is the ONLY force acting on an object, then it will accelerate toward the Earth at 9.8 m/s2.
So when it sits on the launchpad, gravity pulls down with a force, but the ground pushes back with the same exact force, resulting in zero acceleration. When the rocket ignites and exhaust exits the engine, the rocket accelerates upward.
Knowing the actual acceleration of 5 m/s2, can you calculate the amount of thrust necessary to maintain that acceleration? (remember that in F=ma, F is the vector sum of all forces acting on an object).
Likes belledona
Oh, so the net acceleration is 5 m/s^2? (As in, the rocket has already overpowered gravity, so 9.8 does not need to be subtracted from 5?)
So the thrust will be F=5*mass of the rocket?
If you were to subtract 9.8 from 5 you would get a negative number. Perhaps get into the habit of thinking about what the answer means. Eg What would a negative acceleration actually mean? Is it likely a rocket taking off would have a negative acceleration?
Likes belledona
Let me rephrase that. If acceleration = (net force) / (mass). Net force is vector sum of all forces acting on it. What forces are there and what are the directions?
Likes belledona
  • · Replies 38 ·
9K
