Sum of convergent series HELP!
The discussion revolves around finding the sum of the convergent series given by the expression 6 / ((n+7)(n+9)) from n=1 to infinity. Participants are exploring methods to approach the problem, including the use of partial fractions and telescoping series.
  • Exploratory, Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants discuss the use of partial fractions to decompose the series and explore the concept of telescoping series. There are questions about the validity of the telescoping nature of the series and the implications of the terms involved.
Some participants have provided insights into the structure of the series and how to manipulate it, while others are questioning the assumptions made about the telescoping nature. There is an ongoing exploration of the series behavior as n approaches infinity, with some guidance offered on the interpretation of the resulting sums.
Participants are working within the constraints of a homework assignment, which may limit the information they can use or the methods they can apply. There is also a focus on ensuring that the reasoning aligns with the properties of convergent series.
gitty_678
Find the sum of the convergent series -
the sum of 6 / (n+7)(n+9) from n=1 to infinity (∞)
A) 31/24
B) 45/56
C) 8/11
D) 17/24
E) 23/24
2. The attempt at a solution
I was looking in the book and they had one example that was kinda close so i tried to follow it and i did this...
= 6 times the sum of (1/(n+7))-(1/n+9))
= 6 times (1/8-1/10)+(1/9-1/11)... and so on
but that got me nowhere.
I tried plugging this into my calculator sum(seq(6/(x+7)(x+9),x,1,999,1)
and i got .7023779 which is the closest to answer D --> .70833333
but that's only up to term 999 and how do i know that the series won't get bigger than 17/24?
i found that up to the 7,490th term the sum is .7075417. which is closer so I'm going to go with answer D. :)
Of the million ways you've tried, show us your work for one of them, and we'll give it our best.
My thought would be to start with "partial fractions".
6/(x+9)(x+7)= A/(x+9)+ B/(x+7) so, multiplying by (x+9)(x+7), 6= A(x+7)+ B(x+9). If x= -7, 6= A(0)+ B(2) so B= 3. If x= -9, 6=A(-2)+ B(0) so A= -3:
6/(x+9)(x+7)= 3/(x+7)- 3/(x+9)= 3(1/(x+7)- 1/(x+9))
Sum 6/(x+9)(x+7)= 3[ sum(1/(x+7))- sum(1/(x+9)].
This gives a "telescoping series".
Telescoping series -
(b sub 1 - b sub 2)+(b sub 2 - b sub 3)+(b sub 3 - b sub 4)+ ...
Sum = (b sub 1) - lim (b sub n+1)
So with the telescoping series I get
3[ lim (1/8) - 1/(x+9)]
But that's not right... umm...
are you sure that is a telescoping series?
(1/8 - 1/10)+(1/9 - 1/11)+(1/10 - 1/12)...
i thought the last # in the parenthesis has to be the same as the first # in the next parenthesis.
No, that doesn't have to be the case.
Your series in expanded form looks like this:
3[(1/8 - 1/10)+(1/9 - 1/11)+(1/10 - 1/12) + (1/11 - 1/13) + (1/12 - 1/14) + ... + (1/(n + 7) - 1/(n + 9) + ...]
You should notice that the only terms that are left after doing the subtractions are 1/8, 1/9, and -1/(n + 9), so the sequence of partial sums looks like this:
Sn = 3(1/8 + 1/9 - 1/(n + 9))
As n grows large without bound, what does Sn approach?
oh so it would be 3(17/72)= 17/24
i get it.. Thank you very much!
