Sum of moments on a wheel in 3D mechanics
5 replies · 4K views
Femme_physics
Femme_physics said:
Now does this mean that the sum of all moments on the center of perfect wheels is always 0?
Assuming the angular rotation of the wheel is zero, the the net torque is zero and the sum of the moments is zero.
Aren't A and C of different diameters? If so, the lever arms for T3 and T4 are different. That alters the diagram, but not the relationship.
It looks to me like you are treating the two wheels as one when seen in two dimensions. That would seem to assume that neither moves independently of the other. If they can spin freely the net moment need not be be zero.
You're right they're different diameters. It should be
http://img714.imageshack.us/img714/8756/bebebebebe.jpg
Ignoring the length of the vectors
I wasn't told anything about the angular rotation of the wheel. Actually, let me just write the question
"Shaft AD is supported by bearing D and B (the bearings don't have any pivotal forces) On the shaft are strap-wheels A and C. On the straps are acting forces as described in the drawing. The shaft is at uniform circular motion..
Given: Radius of wheel A is 50mm and radius of wheel C is 40mm"
Nothing about "angular rotation"
I see what you mean. But based on the question my assumption was correct, right? Since they're both attached to the same rotating shaft.
There must be more to this question than you have let on?
You are told that the shaft undergoes uniform circular motion.
Yes posted just before you posted :)
Ah, so that's the key! :) I see now! The principles of mechanics are seemingly infinite and interesting!
Thanks Doc, Fewmet, Studiot!
