Solving f(x) and Questions on Solution
  • Thread starter Thread starter sonya
The discussion revolves around finding the inverse function f^(-1)(x) for f(x) = (2e^x - 8)/(10e^x + 9). Participants clarify that f^(-1) is not the same as 1/f, emphasizing that the inverse function satisfies f(f^(-1)(x)) = x. Algebraic manipulation is suggested to derive the inverse, leading to the expression f^(-1)(x) = ln(8 + 9x) - ln(2 - 10x). Confusion arises regarding the notation, with some participants mistakenly equating the inverse function with the multiplicative inverse. The conversation highlights the importance of understanding function inverses in mathematical notation.
sonya
sum1 here help!
ok...since no1s helpin in the hmwk section thot id take a shot here..
if f(x)= (2e^x -8)/(10e^x + 9)
then wat is f^(-1)(x)?
i first took the ln of both sides...
getting lny = ln (2e^x - 8)/(10e^x + 9)
then using one of the properties i get
lny = ln (2e^x - 8) - ln (10e^x + 9)
and from here i get stuck...how do i solve for x?? am i doing it a totally wrong way?? please help!
and i did get a sol'n from sum1 but i had a question abt it...some1 b kind enuf 2 help!
Mathematics news on Phys.org
f^-1 = 1/f
1/((2e^x -8)/(10e^x + 9)) = (10e^x + 9)/(2e^x -8)
then you can work to write this function simpler.
f-1 is the inverse of f, where f is a function.
f-1 does not equal 1/f
if x^-1 = 1/x
it would mean the same for a function, so
f^-1 would be the same as 1/f
Originally posted by Astrophysics
if x^-1 = 1/x
Sorry, you're wrong Astrophysics. If f is a function then f^-1 is the inverse of the function so that f^-1(f(x)) = x.
You just need some algebraic manipulation first
f = (2e^x -8)/(10e^x + 9)
so, 10e^x * f + 9f = 2e^x -8
so, 10e^x * f - 2e^x = -8 - 9f
so, e^x ( 10f - 2 ) = -( 8 + 9f )
so, e^x = -( 8 + 9f ) / ( 10f - 2 )
so, x = ln[ ( 8 + 9f ) / ( 2 - 10f ) ]
so, x = ln( 8 + 9f ) - ln( 2 - 10f )
therefore f^-1(x) = ln( 8 + 9x ) - ln( 2 - 10x )
oh thanks mathnerd, but...how come when I put this in my calculator I get f^-1 = 1/f and f^-1(f(x)) is not x?
Because your calculator thinks you're talking about the multiplicative inverse. It doesn't realize that you really want the inverse of the function. In mathematical notation f^-1(f(x)) = f(f^-1(x)) = x e.g. cos^-1 x does not equal 1 / cos x, it is instead inverse cos which is the inverse function of the cosine function. In my last post where I solved for f^-1(x), you can easily show that f(f^-1(x)) = f^-1(f(x)) = x
I'm very confused here, I was actually thinking the same thing as my calculator I guess, but I have no idea what these inverse means, is it f^-1 or is it something like f' ?
or you could say cos^-1 x=arccos x
Yes, well ArcCos is nothing but the inverse of the cosine function, whereas 1/cos(x) = sec(x), it is easily shown that sec(x) doesn't equal ArcCos(x). By definition the inverse of an arbitary function f(x) is another function g(x) such that g(f(x)) = f(g(x)) = x. In mathematical notation g(x) = f^-1(x)
inverses and identities.
unification.
multiplication.
1 is the "multiplicative identity." let x be a nonzero real number.
x * x^-1 = x^-1 * x = 1. in effect, the thing and its inverse cancel, leaving the identity.
functions.
let * stand for the composition of functions. so rather than write
f(g(x)), write f * g (x).
f * f^-1 = f^-1 * f = I. by, "I", i mean the "identity function,"
I(x) = x.
except for zero, all numbers have a mulitplicative inverse. not so for functions. for example, the function f(x) = x^2 has no inverse defined on the set of real numbers. however, if restriced to nonnegative numbers, f does have an inverse, namely the square root of x. that is precisely what will "cancel" or "oppose" the operation of squaring.
cheers,
phoenix
