Asamad
- 4
- 1
What is the Sun ray brightness quality after mirror reflection and what affects it? How to get the efficiency after reflection?
The brightness quality of sunlight after reflection is significantly influenced by the type of mirror used. Normal vanity mirrors, which typically feature aluminum as a second surface, achieve around 90% reflectivity. Factors such as the transparency of the glass and the surface finish, including silver, aluminum, tin, and nickel, play critical roles in determining mirror quality. To accurately assess the reflective quality of an unknown mirror, utilizing a photometer is essential for measuring the difference between the source light and the reflected light.
This discussion is beneficial for optical engineers, physicists, and anyone involved in the design or evaluation of reflective surfaces, particularly in applications requiring precise light manipulation.
Thanks Andy for your answer. :)Andy SV said:It depends on the mirror
Normal vanity type mirrors are aluminum second surface at 90% reflectivity
The transparency of glass first or second surface silver aluminum tin nickel the finish of the surface
All are variables in mirror quality
If you want to measure the quality of an unknown mirror you need a photometer
Then you can measure and calculate the difference between source and reflection.
