Sunlight, Intensity, electric field RMS
3 replies · 4K views · last reply
ooohffff
Estimate the rms electric field in the sunlight that hits Uranus, knowing that the Earth receives about 1350 W/m2 and that Uranus is 19.2 times farther away from the Sun (on average) than is the Earth.
I=cεoErms2
E=V/d
Eearth=V/d
Since Uranus is 19.2 times farther away then:
Euranus=Eearth/19.2
Iearth = 1350 W/m2
Iearth=cεoEearth rms2
Euranus rms = Eearth rms / 19.2 = √ ( I / (cεo)) / 19.2
= 37.14 V/m
I got this problem wrong several times so I just wanted to verify that I did it right this time. Thanks!
Be aware that saying the electric field is equal to the electric potential divided by distance implies that you are assuming a constant electric field. In actuality the electric field equals the negative gradient of the potential.
But yes, that answer does look right. I just calculated it using the relation between power and intensity, calculating the intensity for a distance 19.2 times greater, and plugging into your equation, and I came out with 37.15 V/m.
