Surface Area of a Multivariable function
The discussion revolves around calculating the surface area of a multivariable function defined as f(x,y) = x*(y^2)*e^(-((x^2+y^2)/4)). Participants are exploring the setup for the double integral required to find the surface area and are encountering difficulties with computation and simplification.
  • Participants discuss the use of numerical methods and software like MAPLE and Wolfram Alpha for integration. Some suggest using spherical or cylindrical coordinates, while others question the appropriateness of these coordinate systems given the function's shape. There are inquiries about the limits of integration and whether the integral can be evaluated by inspection. Suggestions for parametrization and consideration of symmetries in the function are also raised.
The conversation is ongoing, with various approaches being suggested, including numerical integration and potential parametrization. Some participants have pointed out mistakes in earlier reasoning, while others are exploring the implications of the function's properties on the integration process. There is no explicit consensus on the best method to proceed.
Participants note that the function may not have a closed-form solution for the double integral, indicating a need for numerical approaches. There are also discussions about the shape of the region over which the surface area is to be calculated, which influences the choice of integration method.
mariya259
I don't know how to calculate the surface area after setting everything up. I have tried both MAPLE 15 program and wolfram alpha, but I can't find the answer.
I have the function:
f(x,y)= x*(y^2)*e^-((x^2+y^2)/4)
The form I found for surface are was the square root of (sum of squares of partials with respect to x and y).
The work I have so far
∫∫√(e^(-(x^2+y^2)/4))*(y^4-(3x^2*y^4)+(4y^2*x^2)+((x^4*y^4)/4)+((x^2*y^6)/4)+1 dx dy
I have to integrate from -3 to 3 for both x and y.
I have tried putting it into MAPLE 15, but it won't solve the function for a value.
What should I do? Is there any way to simplify this algebraically so that it is easier to solve? Is it even possible to solve it by hand?
try spherical/cylindrical coordinates
What would the limits of integration be though? It is not shaped anything like a cylinder or sphere.
I doubt that there is a closed-form formula for the area, so try a numerical approach. If you call dA your integrand, the following works for me in Maple 11:
Jx:=evalf(Int(dA,y=-3..3));
Area:=evalf(Int(Jx,x=-3..3));
Area := 44.43229369
RGV
[STRIKE]Isn't it an odd function in the appropriate sense? You do not have to do the integration, you can realize the value "by inspection".[/STRIKE]
Ray Vickson has pointed out below that I made a (large) oversight.
I think you have misunderstood the problem. For a graph of the form [itex]z = f(x,y)[/itex] the surface area S of the graph over a region [itex]A \subset R^2[/itex] in (x,y)-space is
[tex]S = \int\int_{A} \sqrt{1 + f_x^2 + f_y^2} \: dx \, dy,[/tex]
where [itex]f_x = \partial f/\partial x,\; f_y = \partial f/\partial y.[/itex] For [tex]f = x y^2 \exp{\left(-\frac{x^2 + y^2}{4}\right)}[/tex] we have
[tex]f_x = \frac{1}{2}y^2 (x^2-2) \exp{\left(-\frac{x^2 + y^2}{4}\right)}\\<br /> f_y = \frac{1}{2}x y (y^2-4) \exp{\left(-\frac{x^2 + y^2}{4}\right)}.[/tex]
Do you really think the double integral S can be evaluated by inspection?
RGV
Yes, that was my mistake, thank you Ray!
Try parametrising it in some other way.
[STRIKE]So dimension10, are you thinking some thing like polar coords., r goes from 0 to 3 cos theta?[/STRIKE]
Oh yeah sorry, I'm not reading very carefully.
[Post cleared]
never mind, deleted
how would i parametrize this function?
I'm not sure but I would suggest a way through which you can use some algebraic/trigonometric identities OR reverse chain rule/reverse product rule.
No matter what you do the function will not have a closed-form double integral. The only reason to bother parametrizing is to make it easier to fit the shape of the region [itex]A \subset R^2[/itex] over which you want to take the surface area. So, if A is rectangular with sides parallel to the x and y axes, just use the original parametrization. If A is a circular disc, you could switch to polar coordinates. If A is an elliptical disc, re-scale x and y to make it a circle, then switch to polar coordinates. In every case you will be forced to get a numerical answer.
RGV
with your region, in wolfram alpha, I think you need to put the 1 outside the parenthesis in the square root
observe some of the symmetries, even along y, odd along x. so your surface area would basically be 4x (integral over region of [0,3]^2)
  • · Replies 40 ·
