What is the true surface area of the Earth according to General Relativity?
The discussion centers on the measurement of the Earth's surface area in the context of General Relativity. Participants clarify that the Earth is not a perfect sphere but an ellipsoid, which complicates surface area calculations. The formula 4πRe2 is established as the correct representation for the surface area of a sphere, while the notion of using 4π2Re2 is dismissed as incorrect. The conversation emphasizes that area measurement relies on infinitesimally small squares rather than large rectangles, highlighting the importance of local geometry influenced by mass.
  • Understanding of General Relativity concepts
  • Familiarity with geometric principles of ellipsoids
  • Knowledge of surface area formulas for spheres
  • Basic comprehension of local versus global geometry in physics
  • Study the implications of General Relativity on local geometry
  • Explore the mathematical derivation of surface area for ellipsoids
  • Learn about the differences between spherical and hyperbolic geometries
  • Investigate the concept of curvature in spacetime and its effects on measurements
Physicists, mathematicians, and students interested in the applications of General Relativity, as well as anyone studying the geometric properties of planetary bodies.
rohanprabhu
I have a very faint idea of General Relativity.. hence this question. I think that according to General Relativity, the shortest distance between two points on this Earth is along a curved path, which is the curvature of the Earth [or sorta.. parallel to it]. Hence, i assumed that when on earth, we measure an area of the land, and we treat it as a rectangle, we are not making an approximation, but that, in fact is the actual area we calculate on this earth.
so, is it true that if we are to measure the surface area of the Earth while being on the earth, we will measure it to be 4\pi^2 R_e^2 rather than 4\pi R_e^2??
lol i really did not know dolphins lived in iglooes.. cartman is soo smart..
sorry but becouse of the geological imperfection of our planet neither of your formulas will work.. For one the Earth is not a sphere, its an elliptoid. this means that the circumference around the equator and the circumference around the poles has a difference of thousands of miles. Also if you try to measure it manually using "rectangles" by the time u finish the surface area will be vary different and you have to start over.. someone else can help you with those formulas cause i have no clue what they mean.. ha ha they wernt on my GED test
i know about the geological imperfections and how the Earth is not a sphere but an ellipsoid. The question I asked was a theoretical one, so practical considerations, as you mentioned aren't necessary.
in that case, I suggest that you should stop being a troll...
Hi rohanprabhu! :smile:
No, General Relativity doesn't do Earth's.
Loosely speaking, the "shortest distance" in General Relativity is the space-time path followed by a body under zero force (so free-falling or orbiting, or just drifting). I think. :rolleyes:
… when on earth, we measure an area of the land, and we treat it as a rectangle …
There's no such thing as a rectangle on a sphere … the sum of the angles of any quadrilateral is always more than 360º.
I'm not following you … where does the π² come from? :confused:
first of all, thanks for the quick reply.
From assuming that the sphere is a folded rectangle, where each side is of length 2\pi R_e (i.e. the equatorial line and one of the latitudes perpendicular to it can be spread out to form a large rectangle, which is cut into four rectangles by these axis and the intersection of these axis is the center of that rectangle). The surface area of such a rectangle would be 2\pi^2 R_e^2.
Now I understand. In that case …
No, definitely not, no way.
General Relativity doesn't work like that, not even remotely like that.
Area is measured by using infinitesimally small squares and pretending they're flat, not by measuring large squares and pretending they're flat. :smile:
ahan.. i get it now. Originally, i wasn't thinking that we measure large squares and pretend that they are flat. What i was thinking was that due to the curvature of the spacetime deformed by the gravity, we have a different geometry local to a mass than a geometry far away from a mass.
Something like what the density parameter defines. For ex:
cited from http://en.wikipedia.org/wiki/Ultimate_fate_of_the_universe[/color][/size]
If Ω<1, the geometry of space is open, i.e., negatively curved like the surface of a saddle. The angles of a triangle sum to less than 180 degrees, and lines that do not meet are never equidistant; they have a point of least distance and otherwise grow apart. The geometry of the universe is hyperbolic.
This is something I thought would happen locally. I am not saying that the reason would be the same. I am just saying that as the geometry of the Universe could be hyperbolic, I assumed that due to a mass, it changes the local system such as to make the geometry locally spherical and hence all straight lines are basically curves when viewed from an external frame and hence the 'flat' for an internal observer would appear to be curved to an external observer. In short I assumed that the geometry of the universe was relative.
Thanks for clearing that up :D
  • · Replies 29 ·
  • · Replies 33 ·
