Swapping 3 integers in C program
  • Thread starter Thread starter kthouz
    Integers Program
The discussion centers on techniques for swapping three integers in C programming. It highlights two primary methods: the divide-and-conquer approach, which involves swapping pairs of integers sequentially, and an all-in-one method that uses arithmetic operations to achieve the swap without temporary variables. The use of bitwise XOR operations for swapping is also mentioned, with some arguing against its practicality in high-level languages like C due to potential issues with compiler optimizations and undefined behavior from signed integer overflow. The conversation touches on the implications of using different arithmetic methods and the importance of understanding how these operations can affect program behavior, especially in edge cases. Overall, the thread emphasizes the need for clarity in swapping techniques and the potential pitfalls of various approaches in C programming.
kthouz
Hi! i have a problem about swapping three integers in C program.
Usually i use the call by reference for two integers only. Now for three i can't get t.
Technology news on Phys.org
I usually create a temporary variable to hold a value while I am doing a swap. Would that do the trick?
Or the old fashion way, more instructions but no temp variable for a swap:
A ^= B
B ^= A
A ^= B
A 3 variable swap is really a rotate.
T = A
A = B
B = C
C = T
To swap 3 integer consider the following 2 methods:
* divide to conquer: swap 2 by 2
swap A & B
A = B+A
B = A-B
A = A-B
then swap A & C or B & C
* all in one:
let the variables A, B & C have the initial values A0,B0 & C0 respectively
A = A+B+C (A0+B0+C0)
B = A-B-C (A0+B0+C0 - B0 - C0 = A0)
C = A-B-C (A0+B0+C0 - A0 - C0 = B0)
A = A-B-C (A0+B0+C0 - A0 - B0 = C0)
Correct me if I am wrong.
http://ghazi.bousselmi.googlepages.com/présentation2
thanks but i can't really get it!
i was expeting of having at least 5lines. (because number of possible swaps=n!)
indeed we are preparing our exam,the teacher didn't explain it clearly and he just told us to figure it out ourselves. please gimme an full example so that i can see the whole format.
All possible swaps? There are 6 ways you can order 3 variables.
A B C // no swaps
A C B // swapsecondpair
B A C // swapfirstpair
B C A // swapfirstpair, swapsecondpair
C A B // swapouterpair, swapsecondpair
C B A // swapouterpair
Code:
int A, B, C, T;
void swapfirstpair()
    T = A;
    A = B;
    A = T;
void swapsecondpair()
    T = B;
    B = C;
    C = T;
void swapouterpair()
    T = A
    A = C
    C = T
swap A & B
A = B+A
B = A-B
A = A-B
* all in one:
you can do this more efficiently and without rounding errors by using ^ to the same effect
a ^= b ^ c;
b ^= b ^ c;
c ^= b ^ c;
a ^= b ^ c;
swap the variable names to change the swapping that is performed, you can extend this to n variables afaik... this works because ^ preserves information in the same way as + and -, except that because the operation is its own inverse there is one symbol instead of two, also because it is bitwise there is no precision loss.
I can't believe people are recommending the triple xor trick. Yes it is clever, but it's pretty bad to use it in a language even as high level as C.
Compiling your code with any optimization at all will cause the compiler to optimize out the temporary variable.
If you're really interested in using assembleresque tricks, you might as well check out Sean Andersen's Bit Twiddling Hacks.
a ^= b ^ c;
b ^= b ^ c;
c ^= b ^ c;
a ^= b ^ c;
with + and - there is no precision loss neither, there might be some cyclic overflows in the intermediate values, but the final results will always be correct.
As I recall, the C standard says that (signed) integer overflow results in undefined behavior.
Probably. But if the computer uses IEEE arithmetic the overflow won't affect the result as tabchouri says. It would be best to comment this, but most modern systems use IEEE... yes?
I thought IEEE only referred to floating point arithmetic? (In this context)
But yes, most systems will do what you expect it to do. But you shouldn't assume it -- for example, what if someone using some fancy system decides to enable trapping of arithmetic overflow, so as to detect errors? Or you're using some fancy OS that uses trap bits in its integer representations to detect a variety of errors?
I'm always amused by observations such as... signed integer overflow formatting your hard drive is permitted by the C standard. :smile:
Yeah, you're right of course... what is the name for the standard I'm thinking of?
Quite right, and amusing too. :D
  • · Replies 49 ·
